Author Topic: Help with SMD  (Read 4510 times)
Offline lavo-1Topic starter
Help with SMD
« on: January 15, 2012, 10:12:00 am »
I'm trying to fault find on a Humidity controlled extractor fan circuit that has gone faulty in my bathroom.
I have tested all the through hole components and even replaced the OP amp just in case.
The problem is there are six SMD components on the board that I don't recognise and to be honest haven't a clue how to test as I don't know what they are. :-[
They are I believe, SOT-23 packages as I measured their dimensions. They all have three pins/legs.
They have Identity codes of:
A4,
L2 Z2,
LN Y4.
Uploaded with ImageShack.us
I'm sure you guys that work regularly with SMD components will recognise the numbers.
« Last Edit: January 15, 2012, 02:07:42 pm by lavo-1 »
Offline Psi
Re: Help with SMD
« Reply #1 on: January 15, 2012, 11:11:28 am »
They can be quite hard to figure out, but you might get some ideas from
http://elektronik.googlecode.com/files/SMD_Catalog222.pdf
http://www.s-manuals.com/smd/
A component tester really helps for this, as you can easily check if its a transistor, fet or diode and narrow down the possibilities.
« Last Edit: January 15, 2012, 11:13:24 am by Psi »
Offline vtl
Re: Help with SMD
« Reply #2 on: January 15, 2012, 11:32:57 am »
Maybe post a picture. Component location can sometimes give you clues to what it is
Offline Psi
Re: Help with SMD
« Reply #3 on: January 15, 2012, 11:36:11 am »
yeah, and the silkscreen text as well.
Re: Help with SMD
« Reply #4 on: January 15, 2012, 02:08:30 pm »
I've popped some pics in to help ;)
Offline Zero999
  • 0999
Re: Help with SMD
« Reply #5 on: January 15, 2012, 09:01:21 pm »
I think you need to provide more information.
You say it's faulty, how? What does the fan remain on continuously? Does it fail to start? Or does it randomly turn on and off?
Have you tested the fan? and the humidity sensor?
Your pictures are a bit too small to see and you've loaded them to imageshack which I find inconvenient - it's better to upload them here if you can and there's no reason not to if they're under the 1000KB limit.
Re: Help with SMD
« Reply #6 on: January 15, 2012, 10:31:24 pm »
Sorry if the images are too small.
The Fan is running continuous once activated. I have checked the Humidity sensor with a DMM and a kettle and its fine. I have checked all the resistors (smd and through hole) and checked the two smoothing caps.
I rigged up a Triac latching test using an led circuit and a 9v PSU which was fine as it latched on both + and -
I just am not sure on the three legged SMD's as I am not sure what they are. I suspect that they maybe a bunch of Diodes and a FET, but I'm not 100%.
