I already have a linear bench top power supply - 0 - 30 VDC and 0-5A with current and voltage control but I occasionally also need to high current power supply for certain hobby projects like electroplating etc. The requirement is for a DC output may be around 0.5 to 1V and current upto 25A.
I don't need anything elaborate something quick and dirty would do.
Is there any switching topology (non-isolated ok) that can convert the bench top 0 to 30 to say something like 0.5V, 25A, If I look at it the other way I would say a 0-25A adjustable constant current power supply.
What kind of simple switching topologies can provide this kind of constant current.
In case this can be done with a PC ATX power supply with minor modifications etc. is also OK.
TIA
