Will it be a good idea to cut short and get an oscilloscope like the famous "Rigol DS1052E" and learn my way on it. Is it complicated to test ESR's or can it even test in circuit capacitors? What can and can't this model do? Again I'm only probing desktop and laptop computer components.
My cheap multimeter died and I'm planing to spend a couple of hundred $ on a replacement tool/s.
Thanks everyone for all your advice.
imo, the process of measuring the esr with a scope is nice, but not very practicle...
you will never take the time to connect the scope, the frequency generator, the cables, the device under test each time you get a suspect capacitor in a circuit...
you'd better have a small handy device like the smart tweezers , to test it
on my repository, you have the analog esr meters, with simple results on a bargraph that are really enought for this
I build the poptronix one years ago and it save many many boards trust me !!!!
it costed me almost nothing as they were drawers junk components I used to build it
you rarely need to have the exact value of the esr in ohm, and if you need it you will surely have to remove the component to measure it precisely.
