Author Topic: Hey, actually figured something out on my own! (zero-crossing detector)  (Read 2791 times)
Online Analog KidTopic starter
Last night laying in bed I thought, for some strange reason, about how would a guy implement a zero-crossing detector? Odd, since I have no current use for such a thing, but an interesting intellectual exercise nonetheless.
I first thought, as I always do, how would a guy do this using only discretes? Diodes, BJTs, stuff like that.
Couldn't think of how that could possibly be done.
Then it struck me: how 'bout an op-amp a comparator? So I came up with the following scheme:
Now this is totally bare-bones, just a basic proof of concept thing.
This morning at breakfast I cracked open my copy of Horowitz & Hill (The Art of Electronics), looked up "zero-crossing" in the index and found this:
So hey, maybe I'm not as dumb as I think (or as others might accuse me of being). Now of course this is a fully-fleshed-out circuit, just about ready for use, with input protection (and hysteresis!).
I put that inverter after the op-amp because I figured that the output was going to be low, not high, on a zero crossing, but H&H, those clever dogs, just used the inverting configuration of the amp. Doh!
Anyhow, it gave me a slight boost this am. Now if I can just find a project that needs this thing ...
The following users thanked this post: BILLPOD
Offline CaptDon
  • Country: is
Re: Hey, actually figured something out on my own! (zero-crossing detector)
« Reply #1 on: December 23, 2024, 02:34:39 pm »
These were used in older 60Hz digital clocks but line noise caused 'extra' clocking. I have even seen some low grade audio frequency counters that used the line frequency as the time base, in fact I owned an old Heathkit D.M.M. who's accuracy depended on line frequency! That D.M.M. was useless in our mobile broadcast studio when running on generator!
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #2 on: December 23, 2024, 02:52:17 pm »
Output will be both a low and high on zero crossing, so inverting doesn't matter.
This circuit doesn't generate pulses on zero crossing, it produces edges (both positive and negative) on zero crossing. So to obtain classic zero crossing detector you need to add edge detection circuit on output (it could be one XOR element + RC network)
Offline tooki
« Reply #3 on: December 23, 2024, 05:15:18 pm »
Mains-clocked clocks are still super common in appliances (like ovens). Perhaps modern implementations use a bandpass filter to reduce spurious clocking?
« Reply #4 on: December 23, 2024, 08:38:56 pm »
By "this circuit" you mean my dreamt-up one, not the H&H one, right?
I assume theirs produces pulses.
Still learning here.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #5 on: December 23, 2024, 10:12:55 pm »
Both
Offline SteveThackery
« Reply #6 on: December 24, 2024, 09:11:03 am »
I don't understand. Referring to the original "bare bones" circuit, why doesn't it just convert the sine wave to a square wave? Where do the pulses come from?
Offline tooki
« Reply #7 on: December 24, 2024, 10:13:38 am »
Take a look at the waveforms in these crude sketches of mine, attached. The first one is what you mistakenly think a comparator circuit would output. But in actuality you get the second one. In the second one, I have added arrows to the edges so you really see what xvr meant about edges (rising and falling) and how you get both highs and lows at zero crossings.
Offline StrayElectrons
« Reply #8 on: December 24, 2024, 10:29:50 pm »
ZVS (zero voltage crossing) was used on the RCA CTC-203 SMPS.    Only I think 2 transistors, 431 and MOSFET, this circuit is self oscillating.
It doesn't have op-amp at all.
Cheers,
« Reply #9 on: December 24, 2024, 11:12:03 pm »
First of all, thanks for paying attention here.
Answer: they don't.
Feel like I've got a little egg on my face here.
So my attempt was obviously a shot in the dark that missed its mark.
But the Horowitz & Hill circuit? I assumed that it would work as advertised.
Guess what? It doesn't.
I simmed it in LTSpice. Was careful to make the circuit exactly as in the book, except for the comparator: I don't have a model for the LM393, so I used a LT part (LT1720) that should work the same: it's a single-supply (3.3-5V) rail-to-rail device.
Here's the output, just like someone said above: just a square wave:
I'm really surprised that this comes from the esteemed H&H. Is there an error in their circuit? Will it only work with an LM393? What's going on here?
I've attached the .asc file in case someone wants to play around with this (and you can check my rendition for errors).
« Reply #10 on: December 24, 2024, 11:27:16 pm »
Could you possibly provide that circuit, or help me find it? Definitely interested in anything that uses discretes.
Although that doesn't sound like a zero crossing detector so much as an oscillator that has something to do with zero crossing.
Offline themadhippy
« Reply #11 on: December 24, 2024, 11:42:52 pm »
A good source for ole skool  zero-crossing  circuits is the disco lighting controller circuits published by  the hobby mags ,one to get you started https://www.worldradiohistory.com/UK/Everyday-Electronics/90s/Everyday-Electronics-1990-01-S-OCR.pdf
Offline tooki
« Reply #12 on: December 24, 2024, 11:48:46 pm »
Why do you think it’s an error? It’s doing precisely what one would expect the circuit to do. Comparators compare, they aren’t timers.
For use with an MCU, no further circuitry is needed — an MCU can easily be programmed to react to edges instead of levels. (In fact, it is often beneficial to do so even in situations where levels could also be used.)
For circuits that aren’t MCU-based, there are ways to generate pulses from that.
Offline antenna
« Reply #13 on: December 25, 2024, 12:08:16 am »
What about a schmidt trigger (for hysteresis), bias the input using a regulated DC source through a potentiometer, then AC couple the signal to the pot wiper and to the schmidt trigger input.  The pot would control the bias and therefore the crossing point making it easy to set to zero, and then if the output needs to be a different duty cycle, use the rising edge of the output to trigger a 555 or something else.
« Reply #14 on: December 25, 2024, 12:26:38 am »
My bad, I guess. Yes, I know what comparators do, but I had assumed (hoped?) that the output would be tailored to create a pulse instead of just squaring the wave.
Shoulda paid more attention to H&H's description:
The circuit shown in Figure 3.68 generates an output square wave for use with TTL logic (zero to +5V range) ...
And that it does, very well.
I'm looking at that Everyday Electronics article now.
« Reply #15 on: December 25, 2024, 12:27:30 am »
Schmitt trigger.
Offline MrAl
« Reply #16 on: December 25, 2024, 02:55:05 am »
(Attachment Link)
(Attachment Link)
Here's a commercial example...
« Reply #17 on: December 25, 2024, 03:23:00 am »
Thanks. I looked at that. Extracted the following circuit fragment from it:
Does a pretty damn good job of what H&H's circuit above does:
Now, if a guy wanted to turn that output into short pulses--one pulse per zero crossing--how would he go about doing that?
Thinking of playing around with gates: flip-flop?
We want a pulse on each zero crossing. Like what @Tooki drew:
« Last Edit: December 25, 2024, 03:29:39 am by Analog Kid »
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #18 on: December 25, 2024, 09:42:53 am »
2469699-0
IC is 1/4 of 74HC86 or 1/4 of CD4070 or 74LVC1G86
« Reply #19 on: December 25, 2024, 10:09:13 am »
(Attachment Link)
Do we need a diode across R8 to help discharge the capacitor? Actually, no, I can see that it's unnecessary provided the capacitor is small enough to produce a pulse which is very short compared with the sine wave period.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #20 on: December 25, 2024, 10:58:31 am »
Definitely no. Diode across R8 will shrink pulse width for negative edge. Circuit should be symmetrical for both edges, so diode SHOULD NOT be used.
The following users thanked this post: SteveThackery
Offline tooki
« Reply #21 on: December 25, 2024, 11:16:39 am »
There well may exist a chip designed to do just that, but it wouldn’t be sold as a general-purpose comparator. A comparator’s job is to compare. Doing other things falls outside its purview, and besides, would need other components to configure it. (E.g. how long is the pulse? For 50/60Hz mains, where you’d get pulses at 100/120Hz, a pulse length of 5ms is no problem. But at the 400Hz used for aircraft systems, 5ms is longer than the entire period. Never mind at higher frequencies. So you would need a configurable pulse length.)
I checked, and zero-crossing detector (ZCD) ICs do exist, but every one I found outputs a square wave like the comparator.
Given that zero-crossing detection is also used for things like phase measurement, where you need to distinguish between the rising and falling zero-crossings, it seems reasonable to me that ZCD circuits and ICs don’t default to making pulses, since pulses are less flexible, and pulses can be created from the square wave, but phase-accurate square waves cannot be reconstructed from the pulses.
(Attachment Link)
Why do we want that? What is an application where we need two pulses per period and cannot accomplish the same thing with the square wave?
Offline antenna
« Reply #22 on: December 26, 2024, 12:11:55 am »
Schmitt trigger.
I got the spelling from Schmidt beer, honest mistake for a Minnesotan
Online TimFox
« Reply #23 on: December 26, 2024, 12:13:25 am »
Schmitt trigger.
The beer that grew with the great north-west!
« Reply #24 on: December 26, 2024, 12:22:35 am »
Nah, it's Grain Belt for me.
