Very precise and robust detector from:
http://web.archive.org/web/20170704120431/www.dextrel.net/diyzerocrosser.htm
FEATURES:
highly accurate mains zero crossing detection
fully isolated and low voltage safe output
ultra-low power consumption; worst case power dissipation < 120mW
produces symmetrical pulses around zero crossings
output pulse stays constant, independent of the mains voltage
very low parts count, no precision components required
all components can be low voltage SMD
works over all voltage ranges (100VAC/240VAC), without modification
50Hz/60Hz compatible
50Hz produces a 1ms ZC pulse, 60Hz produces 0.83ms ZC pulse
highly stable with varying temperature and aging
