Author Topic: SMD Electrolytic capacitor markings  (Read 2149 times)
Offline will_raymo2000
« on: January 12, 2017, 03:48:56 pm »
Trying to repair a faulty USB soundcard and I suspect a couple of filtering capacitors have given up the ghost. They are surface mount electrolytics with the following markings:
100
6S
E74
I'm guessing 100uF but not 100% sure.
Any help appreciated thanks!
Offline Cupcakus
Re: SMD Electrolytic capacitor markings
« Reply #1 on: January 13, 2017, 08:45:05 am »
Every manufacturer uses different markings so it's hard to know for sure, but with those marks it should be 100uF 6.3V
Offline German_EE
« Reply #2 on: January 15, 2017, 10:34:27 am »
One other thing to note (one of those fabled traps for young players).
A through-hole electrolytic capacitor has the 'band' next to the negative lead
An SMD wet electrolytic in a round can also has the black mark next to the negative lead
An SMD tantalum electrolytic in a plastic case has the mark next to the POSITIVE lead.
Warren Buffett
Offline Howardlong
« Reply #3 on: January 15, 2017, 01:46:56 pm »
I wonder (a) what they were thinking and (b) how many of us found that out the hard way?
Offline German_EE
« Reply #4 on: January 15, 2017, 07:33:11 pm »
Count me among their number which is why I passed the information on, learn from my mistakes.
Warren Buffett
« Reply #5 on: January 15, 2017, 09:24:03 pm »
Just to follow up on this... I replaced it with a 100uf radial capacitor with the leads bent to fit the pads and it didn't work. Replaced that with a 10uf and voila, it worked perfectly.
Still got a very high frequency (audible) whine from something in the power section but it is markedly lower having replaced a couple of these capacitors.
