Author Topic: Setting up Tune Voltage Circuit  (Read 670 times)
Offline metrologistTopic starter
« on: December 03, 2018, 09:18:46 pm »
Hi All,
I am controlling the tune voltage of an oscillator with a 16-bit PWM DAC out from Arduino (from the Lars DIY GPSDO project).
My oscillator needs a smaller tuning range than 0-5V, probably 1-3V or less would be fine. The current tune voltage is about 2.1V. I figured I can wire the DAC out to a 10k trimpot (simulated R1-R4) and use the center tap to the tune pin to increase effective DAC resolution.
Is there an equally easy way to improve noise and temperature stability? I was wondering if a 2.5V voltage reference could be easily used. I probably won't consider anything too complex, including op amps, etc.
« Last Edit: December 04, 2018, 07:19:22 pm by metrologist »
Online David Hess
  • DavidH
Re: Setting up Tune Voltage Circuit
« Reply #1 on: December 05, 2018, 12:23:08 pm »
Improving the noise will mean adding an active low pass filter and removing any ground loops.  Improving the temperature stability will require a stable reference, stable gain, and stable offset.
Potentiometers do not make good precision voltage dividers; a pair of precision resistors should be used instead.
A great improvement could be made by doing the PWM switching closer to the oscillator with the 2.5 volt reference but it would require an analog switch or logic gate.
