Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Hi, how can i adjust the gain of this amplifier circuit to be like the original
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Hi, how can i adjust the gain of this amplifier circuit to be like the original (Read 685 times)
nyame
Regular Contributor
Country:
on:
September 09, 2018, 04:22:41 pm »
Hi please how can i adjust the gain of this amplifier circuit to be like the original as indicate with arrow below, i need to adjust the circuit to amplifier correct with the same original gain as indicate in the uncompleted circuit.
Logged
Audioguru
Super Contributor
Country:
Re: Hi, how can i adjust the gain of this amplifier circuit to be like the original
Reply #1 on:
September 09, 2018, 08:58:15 pm »
They are biased differently with the original collector at half the supply voltage but the new circuit has its collector voltage too high.
The new circuit has too much voltage gain which can be reduced by increasing the value of the 386 ohm resistor. When the emitter resistor value is increased then the collector voltage will drop closer to what it should be. The emitter resistor should be about 456 ohms.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
