Electronics => Beginners => Topic started by: nyame on May 16, 2018, 05:36:05 pm
Title: Hi, How can i determine the cut-off frequency from this op amp graph ?
Post by: nyame on May 16, 2018, 05:36:05 pm
Hi, please how can i determine the cut-off frequency of this op amp graph, and please how can i connect the two curves together ?
Title: Re: Hi, How can i determine the cut-off frequency from this op amp graph ?
Post by: rstofer on May 16, 2018, 11:31:48 pm
You already have the cutoff frequencies where the flat portion of the curve begins to turn down.  About 6 kHz and 80 kHz.
This looks a lot like a gain-bandwidth problem.  If you want 100 dB of gain, the bandwidth is a little over 6 kHz.  If you want 10 dB of gain, the bandwidth is about 80 kHz.
Usually, the cutoff frequency is considered to be the frequency at which the output is 3 dB down.  That's pretty hard to see on a graph of 100 dB but it's pretty easy on a 10 dB graph.
Since the graphs aren't exactly real in the sense of the fall off, it's a little difficult to say whether the lower graph cuts off at 60 kHz or 80 kHz.  Normally, that sharp turn down is at the frequency where the output is already 3 dB down and there is a curve where that sharp turn it located.
Look at the Bode' plot here:
https://en.wikipedia.org/wiki/Cutoff_frequency
You could substitute 60 dB wherever I wrote 80 dB above.
BTW, I'm assuming the vertical axis is dB
Post by: Wimberleytech on May 16, 2018, 11:43:10 pm
Great answer, but I think the vertical axis is V/V (gain of 10 and gain of 100) and not dB.
Post by: rstofer on May 17, 2018, 12:58:02 am
I just came back in to rewrite my reply.  I agree, the graph is probably in V/V.  That makes a lot more sense given the logarithmic scale.  My bad...
The nominal cut-off frequency is still the point where the signal is 3 dB down but that needs to be converted to a voltage ratio and 3dB is 0.707 times the unattenuated voltage.  So, for the upper graph, the cut-off frequency would be the point where the value is about 70.  For the bottom graph, the cut-off frequency is where the value is about 7.
http://www.sengpielaudio.com/calculator-gainloss.htm (http://www.sengpielaudio.com/calculator-gainloss.htm)
Again, these definitions are covered in the Wiki
https://en.wikipedia.org/wiki/Cutoff_frequency (https://en.wikipedia.org/wiki/Cutoff_frequency)
Post by: nyame on May 17, 2018, 12:03:54 pm
thanks sir,
please one more think, how do i connect the 100k and the 10k curves ? please !
Post by: nyame on May 17, 2018, 12:05:27 pm
thanks sir,
please how do i connect the 100k and the 10k curves ?
Post by: Wimberleytech on May 17, 2018, 01:04:22 pm
thanks sir,
I think you are plotting the freq response of an opamp in 1) gain of 10, and 2) gain of 100.  Probably some measurement errors here and there.  Your plots should line up as shown here.
Post by: Mechatrommer on May 17, 2018, 02:18:22 pm
i believe those graphs are "open loop" gain. to decide cut-off frequency, first you decide how much gain you want in your circuit and draw a horizontal line from y-axis to the right. say if you want the gain of 3, we are looking at somewhere cut-off around 300Khz... if you want gain of 5, that is just over 100KHz. fwiw..
you cant and you shouldnt. usually open loop gain will overlap nicely (as Wimberleytech demonstrated). your graph showing different path maybe due to different setup and loading. so to know your opamp exact behaviour, you need to know your real life circuit, feedback and output loading... different loading different plot.
thats why we rely on datasheet plot first as ballpark, and then do real life testing to see if our circuit matches the datasheet plot, it can be off but it should not be far off, many more can be said (on circuit setup), but thats the general idea, ymmv.
Post by: Wimberleytech on May 17, 2018, 02:29:37 pm
Here is  a garden variety 741 open loop frequency plot with the gain of 10 and gain of 100 cases overlayed
Post by: Lee Leduc on May 17, 2018, 02:47:15 pm
This tutorial may help explain what you are seeing.
Notes On Gain-Error In Op-Amp Amplifiers
https://www.elexp.com/Images/Notes_on_Gain_Error_in_Op-Amp_Amplifiers.pdf (https://www.elexp.com/Images/Notes_on_Gain_Error_in_Op-Amp_Amplifiers.pdf)
Post by: nyame on May 17, 2018, 05:26:00 pm
thank you sir,
that area is already connect, i though i needed to connect the upper end also, please do i also need to connect all the gains and frequency respond ?
or better still how should the complete graph set-up look like ?
Post by: nyame on May 17, 2018, 05:31:10 pm
my wish is to graph this results, and identify the cutoff frequency
Post by: Wimberleytech on May 17, 2018, 05:43:53 pm
rstofer has answered your question in his first reply.
Post by: nyame on May 17, 2018, 05:59:35 pm
thank you sir,
does it required that i plot the gain bandwidth product for the above graph, or better still i need you to guide me, i need to produce a graph out of this result ?
 please what should the complete graph look like ?
Post by: nyame on May 17, 2018, 06:03:32 pm
Hi Sir,
thanks for the reply it helps.
please how should a complete graph look like, appart from plotting the results and the cutt-off frequency, is the any additional thing i need to do to make the graph complete ?
Post by: rstofer on May 17, 2018, 07:18:57 pm
Wimberleytech gave you a combined graph above.  What you have is a pair of graphs, one for a gain of 100 and one for a gain of 10.  It should be pretty easy to graph a gain of 20, or 30, or whatever.  You know the outer edge of the gain-bandwidth product.  That's the sloping line.  Pick a gain, get a bandwidth.
I pointed out that the sharp corners don't occur in the real world and, at the cutoff frequency, the output would be 3 dB down or 70.7% of the original value.
The Wiki I linked shows you that the corner is rounded and, in fact the curve passes through the point that is 3 dB down or 70.7% of the original value.
Look at the graph in the Wiki an notice how it is curved.
We get the sharp corners when we approximate the response manually then sketch in the curve to fit.  These are really just approximations, the only real response curve is obtained with a network analyzer like the tool in Digilent Waveforms for the Analog Discovery 2.  Here a signal generator sweeps the frequency spectrum and the analog input is used to compute the graph.
Post by: rstofer on May 17, 2018, 07:40:28 pm
Here's another documented related specifically to gain-bandwidth product.
Note the definition for cutoff frequency
https://en.wikipedia.org/wiki/Gain%E2%80%93bandwidth_product
