So I am about to replace a blown output MOSFET in a Sony TA-FB930R stereo amplifier. Specifically, the Right channel N-channel MOSFET is blown and needs replacement.
Here's part of the circuit diagram, with red dots next to the four MOSFETs (Q511 and Q512 on the left channel, Q612 and Q611 on the right one). x11 are the P-channel 2SK1529-Y ones, x12 are the N-channel 2SJ200-Y ones.
The blow MOSFET is the right-channel PNP 2SK1529-Y. I've used a PeakElec DCA75 to get some measurements of the surviving ones:
As you can see the existing, working MOSFETs have wildly different characteristics (or so I think). Does this mean that the replacement I am looking for can be equally "wild" (while still being within manufacturer specs)?
I know if there were MOSFETs in parallel (e.g. two 2J200s on a single channel), matching was important (usually Vgs and gm), but now I am wondering about this particular circuit and if I am overthinking the replacement of Q611.
