Author Topic: 1-phase motion detector, how does it work?  (Read 6421 times)
Offline somlioyTopic starter
  • Country: no
« on: March 06, 2012, 06:15:25 pm »
Hi
Me and some of my colleagues had a discussion about how 1-phase motion detectors work. They're used for controlling lights etc. Connected like this:
How do they power the electronics inside the detector?  :o
Normally we would use two phase in and get both out to the lights.
Talking about 230v 50hz mains for the records.
Online IanB
Re: 1-phase motion detector, how does it work?
« Reply #1 on: March 06, 2012, 06:24:48 pm »
Could just be a mercury switch?
  • Country: no
« Reply #2 on: March 06, 2012, 06:52:58 pm »
Theres definitively electronics inside. Including a coil, triac, some caps etc. You have the option to choose on-time, lux sensitivity and movement sensitivity with some onboard pots or something.
It's this detector: http://translate.google.com/translate?sl=no&tl=en&js=n&prev=_t&hl=no&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Felko.no%2Fwsp%2Felko2_nor%2Ffrontend.cgi%3Ffunc%3Dcatalog.show%26table%3DPRODUCT%26prod_id%3D12321%26func_id%3D1001%26l3exp%3D1848%26l2exp%3D%26l1exp%3D1845%26template%3Dproduct
Datasheet (page 2 for english): http://elko.no/elko2_nor/frontend/mediabank/17942/Bruksanv4860.pdf
« Last Edit: March 06, 2012, 07:04:14 pm by somlioy »
Offline cybergibbons
« Reply #3 on: March 06, 2012, 07:11:43 pm »
It will either charge a battery or supercap when the lights are on, or pass a very small current through the lamps (not enough to light them) and use this.
  • Country: no
« Reply #4 on: March 06, 2012, 07:14:13 pm »
How does that work considering its the same mains potential at the both side of the detector when the switch is closed.
What about the first power up? And you only have one potential.
« Last Edit: March 06, 2012, 07:15:54 pm by somlioy »
Offline aluck
  • Country: ru
« Reply #5 on: March 06, 2012, 08:48:42 pm »
that's exactly how they work, and for that exact reason they are not suitable for driving energy-saving bulbs
Offline T4P
  • Country: sg
    • T4P
« Reply #6 on: March 07, 2012, 11:05:44 am »
Well , a phototransistor .
Then the relay on the live line .
  • Country: no
« Reply #7 on: March 07, 2012, 06:38:59 pm »
Ok, so how does that work in practice?
« Reply #8 on: March 07, 2012, 07:12:46 pm »
Are you stating that there is the same mains potential at each side of the device because you have measured it? Or because you are viewing it as a simple switch, and have assumed that is the case?
Offline aluck
  • Country: ru
« Reply #9 on: March 07, 2012, 07:20:31 pm »
Why don't you just disassemble one?
  • Country: no
« Reply #10 on: March 07, 2012, 07:28:11 pm »
The latter.
Yeah, I will. But since I'm an electrician tracing pcb routes arent my stronges side.
Offline sacherjj
« Reply #11 on: March 07, 2012, 07:37:25 pm »
These are just a PIR sensor: http://en.wikipedia.org/wiki/Passive_infrared_sensor
The information from that controls a power switching circuit, either solid state or relay.
« Reply #12 on: March 07, 2012, 08:21:28 pm »
Generally they have a capacitor power supply, with a triac providing the drive. They get power when on by only switching the triac on after the instantaneous voltage is over around 20V, so they can have an internal regulated rail.
The problem with them and energy saving lamps is the low power draw when off is often enough to charge up the internal capacitors in the lamps, and this causes the lamp to flash every few seconds ( a single short dim flash normally) as the internal lamp circuit starts up and discharges the capacitor. This kills the CFL unit quite fast from the repeated failed starts.
Offline T4P
  • Country: sg
    • T4P
« Reply #13 on: March 07, 2012, 09:28:07 pm »
Beyond normal operation ( like if they are pulsed , as you might have seen with capacitive dividers ) they get pure DC and what does that do ! Well , THE CAPS ARE KILLED !
If you pulse a capacitive divider they are gonna blow up !
CFL's die from repeated starts yes , but the capacitor blows up first .
Offline qno
« Reply #14 on: March 10, 2012, 08:47:14 pm »
I think these devices use a thyristor.
They work the same way as a dimmer.
Only the potmeter has been replaced wit a LDR.
If you look to the voltage over these devices with a isolated scope or a scope with a differential input (do not use a standard scope) you can see that the first 5 or 10 volts of the mains sinus is used to trigger the the thyristor.
Why spend money I don't have on things I don't need to impress people I don't like?
