I should think some wideband devices fitting that description should be easy to find. -50 is way up out of the noise floor so you don't need a super low noise figure and adding 30Db of gain you are still at -20 so it isn't exactly a power device either. I am certain readily available prepackaged devices with SMA connectors exist. Seems like bare MMIC's would be available. 1 50 ohm input lead, 1 50 ohm output lead which gets D.C. power through a choke and a grounded body / substrate. I wonder if any of the wideband devices rated for +10 to +30 DBm would work for you? They are certainly made. Up to 40Db gain blocks.
