One idea is to use a variac if you have and note which voltages you will use, and order a transformer with some outputs that much your voltages, or a 1:1 transformer and a selector to select some capacitors to have some speeds like some cheap ceiling fans. I have one 30W i dont know if it is much difference for your 160W fan. Also look for the wall selektor for ceiling fans in factories
