Author Topic: High Quality Banana Plug from SPC but how to Connect???  (Read 1529 times)
Offline K1JOS
« on: September 01, 2017, 09:26:27 pm »
I am embarrassed to ask the question.   I came across a large stash of super high quality banana plugs and several nice used HP6236B's to use as linear power supplies for my projects.  How the heck is this solder-less banana plug connected to wire?  At first I thought after wire pushed through the smaller screw stud, the excess strands should be folded back much like a compression fitting but when done this way - impossible to screw the small stud back in without cutting through the strands.  Attached are picture and manufacturer's sheet.  I must be overlooking something very obvious.
Thanks in advance
Jerry
Offline Benta
Re: High Quality Banana Plug from SPC but how to Connect???
« Reply #1 on: September 01, 2017, 10:01:08 pm »
I'd say you have low standards  ;D
Anyway, just push in your stranded wire, and tighten the small screw. There's a kind of tapered point that spreads out the strands, so the hollow screw can press them tight.
Offline cvanc
« Reply #2 on: September 01, 2017, 10:57:55 pm »
It may or may not be correct according to the vendor, but I've seen plenty of these with the wire soldered in to the small part.
Offline nanofrog
« Reply #3 on: September 02, 2017, 01:50:17 am »
If your wire isn't spreading out to create a good electrical and mechanical contact as previously mentioned, then soldering it to the smaller threaded insert would be the way to go.
Personally I prefer the retractable + stackable types, such as Mueller BU-3261410. And there are decent copies of these that won't break the bank (genuine Mueller's are a bit over $5 a pop; copies can be had for ~$1 per and are decent - example).
Other quality brands to consider would be Pomona or Cal-Test next time you're in the market.  ;) And there are also decent silicone insulated patch cords IME, using both retractable & non-retractable connectors in various colors (beyond black & red). You can even get silicone wire on eBay in small lengths in various colors as well (I currently have some 20, 18, and 14AWG on hand).
Offline eblc1388
« Reply #4 on: September 02, 2017, 08:11:10 am »
Beware of buying cheap banana plug/socket made of iron instead of brass. You'll get what you pay for.
Offline tooki
« Reply #5 on: September 02, 2017, 11:52:05 am »
Thanks in advance
Jerry
FYI, the datasheet for the plug in the picture (in the baggie) says it's a solder connection: http://www.farnell.com/datasheets/1656947.pdf
Offline tooki
« Reply #6 on: September 02, 2017, 11:53:53 am »
I suspect that's exactly how these are supposed to be used.
Offline K1JOS
« Reply #7 on: September 02, 2017, 04:27:29 pm »
Thanks, soldering was the only way I could find to make them work.
Offline Electro Fan
« Reply #8 on: September 02, 2017, 07:36:09 pm »
+1 for retractable and/or stackable and Cal-Test
« Last Edit: September 02, 2017, 07:38:18 pm by Electro Fan »
