Author Topic: high voltage across relay contacts?  (Read 2408 times)
Offline electronics manTopic starter
« on: May 22, 2015, 03:01:35 pm »
i have an application where there may be a hight voltage across the contacts of a relay however it will never be switching that high voltage. most relays are only rated to switch about 30V however i won't be witching that voltage . my question is is it ok to have this voltage across contacts without switching it even though the relay is rated to switch a lower voltage and can i increase the breakdown voltage across contacts by putting relay contacts in series (increased gap = increased breakdown voltage)  O0 O0 O0 O0
follow me on twitter @get_your_byte
Offline Pillager
  • Country: at
Re: high voltage across relay contacts?
« Reply #1 on: May 22, 2015, 03:32:45 pm »
... can i increase the breakdown voltage across contacts by putting relay contacts in series (increased gap = increased breakdown voltage)
I wouldn't do that. Yes, it is theoretically possible, but not recommended. Buy a suitable relay for the voltage you're expecting, it's your safest bet.
BTW, how high is High Voltage?
Greets
Tom
« Reply #2 on: May 22, 2015, 03:51:36 pm »
i meant to put in 1KV MAX
Offline PSR B1257
« Reply #3 on: May 22, 2015, 04:18:25 pm »
Depends on the relay.
The nominal switching voltage is here not determining, since this is the voltage where the relay is able to switch it's rated nominal current.
Take a closer look in the datasheet. You will find a figure called Dielectric strength for the contacts.
Here is an (random) example: http://www.omron.com/ecb/products/pdf/en-g5le.pdf
« Last Edit: May 22, 2015, 04:20:33 pm by PSR B1257 »
In theory, there is no difference between theory and practice. But, in practice, there is.
Offline Asmyldof
  • Freelancer - Persnicketist - Do'er of stuff
    • Asmyldof's Home. It's old, not quite impressive, but it's there.
« Reply #4 on: May 22, 2015, 09:01:42 pm »
And for the general question of "Can I do this with a relay" always take the lowest dielectric withstand/strength you can find, unless you know which one to pick for your exact situation.
If it's a puzzle, I want to solve it.
If it's a problem, I need to solve it.
If it's an equation... mjeh, I've got Matlab
(not really though, Matlab annoys me).
