Author Topic: n00b Scope question  (Read 2975 times)
Offline ScottyAUTopic starter
    • ScottyAU
n00b Scope question
« on: June 26, 2014, 07:05:11 am »
Hi all,
I've just got a new bench power supply - and I've been playing around with it with my scope - looking at the noise on/off etc.
I have a Rigol DS2072 with the 300Mhz "option" - but still on v2 - haven't touched v3.
My question is - I have my bench supply set to 5v. (the setting doesn't matter but let's go with 5v).  If I meter across the outputs with my multimeter I see bang on 5v.  If I connect my scope though - I only see 1v.  If I chance the setting on the bench supply to say 10v - the multimeter sees it just fine - but the scope sees 2v.
What am I doing wrong on the scope to get the scale/output on the scope wrong like this?  (I've tried a restore to defaults with no luck).
Cheers.
Scotty
Offline tautech
Re: n00b Scope question
« Reply #1 on: June 26, 2014, 07:15:31 am »
You say you see 1 or 2 V.
How do you see this?
Are you reading this from the graticules?
Or from some on-screen measurement?
What is your vertical attenuator setting?
Is the Ch input set to match the probe?
Avid Rabid Hobbyist
    • ScottyAU
« Reply #2 on: June 26, 2014, 07:16:58 am »
I figured it out - I have 10x probes but only had them set to 1x in the channel settings.
Setting it to 10x I now see the correct voltage...
Cheers!
    • ScottyAU
« Reply #3 on: June 26, 2014, 07:17:31 am »
PS - thanks tautech for the reply.
Offline tautech
« Reply #4 on: June 26, 2014, 07:23:14 am »
Scotty, have you worked out that to measure ripple, you need to set your channel input to AC coupling and lower V/div.  :)
Avid Rabid Hobbyist
    • ScottyAU
« Reply #5 on: June 26, 2014, 07:24:52 am »
I've been playing with different scales on the v/div etc - but i'll set it to AC coupling now - ta for the tip!
Offline w2aew
    • My YouTube Channel
« Reply #6 on: June 27, 2014, 04:17:18 pm »
Here's a video of mine that describes scenarios where AC or DC coupling are useful:
FAE for Tektronix
    • ScottyAU
« Reply #7 on: June 27, 2014, 07:54:08 pm »
I'm still working my way through a lot of your videos w2aew - thanks very much!
