Author Topic: 852Dplus Nozzles  (Read 557 times)
Offline bostonmanTopic starter
852Dplus Nozzles
« on: June 01, 2021, 02:55:33 am »
Has anyone purchased nozzles for the 852Dplus hot air pencil?
I'm looking to replace an Agilent hybrid chip (see attached) and looking to get a square nozzle, however, the few I've found are expensive.
Does anyone know a good place to get these?
Offline knapik
Re: 852Dplus Nozzles
« Reply #1 on: June 01, 2021, 06:07:00 am »
Any specific need for a square nozzle? I would expect just a large circular one to be good enough for the job.
« Reply #2 on: June 01, 2021, 01:26:18 pm »
I assumed a square one would apply heat evenly.
You're correct, a large round one would work too, but I'm uncertain if you mean to use the smaller circular that came with it or buy a large one that would fit around the square IC.
If you mean buy a large circular to fit around the square IC, then I'd imagine buying a square would be ideal.
