Author Topic: high voltage transistors  (Read 1858 times)
Offline malch
« on: June 18, 2014, 02:53:16 pm »
I thought transistors were only good for may 100 volts, but look at this listing.
A thousand volts with no relays!
http://www.ebay.ca/itm/FUJI-ELECTRIC-1000V-150A-TRANSISTOR-MODULE-2DI-150Z-100-/271097966519?pt=LH_DefaultDomain_0&hash=item3f1eb2afb7
And 150 amps is no slouch either!
How do they do it?
Offline theatrus
Re: high voltage transistors
« Reply #1 on: June 18, 2014, 03:10:20 pm »
Devices like IGBTs have quite high voltage capability:
http://www.digikey.com/product-search/en?pv814=17&pv814=28&pv814=152&pv814=15&pv814=156&pv814=132&pv814=153&pv814=38&pv814=41&pv814=36&pv814=18&pv814=20&pv814=135&pv814=37&FV=fff40015%2Cfff8007e&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
Some classic bi-polar devices can go to 1kV, but they are rarer. Devices like SCRs are 'readily' available in transmission line voltage capabilities.
In this case, there are likely a set of parallel IGBT dies bonded into that brick for the current handing capability.
Software by day, hardware by night; blueAcro.com
Offline malch
« Reply #2 on: June 18, 2014, 03:29:29 pm »
Hmm I think of "transistors" as analog amplifiers, and thyristors for SCRs or switches.
Learn something new every day.
« Last Edit: June 18, 2014, 09:24:10 pm by malch »
Offline iRad
  • Are you sure it's safe?
« Reply #3 on: June 18, 2014, 03:40:49 pm »
How do they do it?
This is how...
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #4 on: June 18, 2014, 04:34:30 pm »
Grins.. IGBT's are the meat & potatoes of a modern day Tesla Coil.. wooo-hahhahah
Recharged Volt-Nut
Offline Shredhead
  • Yup
« Reply #5 on: June 18, 2014, 05:33:44 pm »
What are you supposed to heat sink it to your car or something?  :o
« Reply #6 on: June 18, 2014, 06:29:37 pm »
Those high power bipolar devices were very common in ferroresonant UPS devices, as they only needed a simple heatsink about the size of a shoebox to handle 1kVA of power, fed from a 48V battery bank. You also had on there the 2 smaller Semikron SCR half bridges used to charge the battery and provide float voltage control. The only problem was the bipolar blocks were obscenely expensive, and any fault on the driver board meant a blown 400A Dc bus fuse, and one dead transistor block. I took a few apart, the bipolar active device inside is a pair of 1cm diameter disc of silicon, mounted on a aluminia insulator and then bonded to a massive Kovar heat spreader. Leads are thick ribbons for C and E with a thinner set of leads for the base and the emitter sense connections. Later on you had a half meter long heatsink with a lot of parallel 2N3773 transistors on it, using a thin 1mm wire from each emitter as balancing resistors to prevent hotspotting. Fixing was a matter of repairing the driver board, then test it with some 12V lamps in series then getting a box of 100 power devices and a tub of heatsink compound out. One mistake and you have a lot of smoked silicon.
