Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
JB Capacitor temperature coefficient for nvme data lanes good?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: JB Capacitor temperature coefficient for nvme data lanes good? (Read 1047 times)
The Mad Atheist
Newbie
Country:
on:
July 17, 2021, 02:26:05 pm »
Hi, I'm installing the 2nd m.2 components to my MSI GL65 Leopard 10SEK-022 laptop that MSI decided to not put on.
Looks like I can only get 0201 220nF caps with JB, similar to X5R ( -25°C ~ 85°C ) temp coefficients. Someone recommended X7R or C0G ones.
Any feed back for these in this use case?
https://www.digikey.com/en/products/detail/C0603JB1A224K030BB/445-10754-1-ND/3952420?itemSeq=371312745
--------OLD POST INFO, DISREGARD-------
Specs say 220np 10v 0201, but the smallest I can find on their site or 25v.
https://www.digikey.com/en/products/detail/GJM0335C1ER22WB01D/490-17301-1-ND/7602300?itemSeq=371149156
Would there be any issues using a higher voltage for the data lanes?
thanks, d.
Last Edit: July 18, 2021, 05:14:33 pm by The Mad Atheist
Logged
The Mad Atheist
Newbie
Country:
Re: Higher voltage capacitors for nvme data lanes.
Reply #1 on:
July 17, 2021, 02:28:28 pm »
Closer pic of C1572-C1579.
Logged
daqq
Super Contributor
Country:
Reply #2 on:
July 17, 2021, 07:35:47 pm »
There shouldn't be any issues with higher voltage, but are you sure you got the right capacitor? 0.22pF sounds too low for, well, anything? IIRC the recommended coupling capacitor for PCiE were in the tens/hundreds of nF region. Are you sure it's not supposed to be 220nF or some such?
Last Edit: July 17, 2021, 07:38:33 pm by daqq
Logged
The Mad Atheist
The Mad Atheist
Newbie
Country:
Reply #3 on:
July 17, 2021, 10:08:48 pm »
Whoops, used a P instead of a F.
Yes, the caps I need are 220nF or .22uF
Edit, wow, glad you caught that!
Thx, d.
Logged
The Mad Atheist
Newbie
Country:
Re: JB Capacitor temperature coefficient for nvme data lanes good?
Reply #4 on:
July 18, 2021, 10:26:28 pm »
OK, finally fixed the error.
Looks like I can only get 0201 220nF caps with JB, similar to X5R ( -25°C ~ 85°C ) temp coefficients. Someone recommended using X7R or C0G ones.
Logged
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Reply #5 on:
July 18, 2021, 10:29:51 pm »
X7R and X5R are very similar for your case, and 220nF C0G capacitors are expensive and bulky, so you need a very good reason to use C0G for your application. I’m quite sure that 220nF C0G does not exist in 0201. The last ones I bought (for a good reason in an analog application) were 1812 or some such size.
Last Edit: July 18, 2021, 10:31:40 pm by TimFox
Logged
The Mad Atheist
The Mad Atheist
Newbie
Country:
Reply #6 on:
July 19, 2021, 07:05:06 pm »
Thanks for the reply, I saw the temp curve and thought I ask to be safe.
Logged
The Mad Atheist
Newbie
Country:
Reply #7 on:
July 19, 2021, 07:32:27 pm »
Might as well post my part list for review just in case I have another error or missed something.
thx, d.
0.22 µF ±10% 10V Ceramic Capacitor JB 0201 (0603 Metric) for C1572-C1579.
The m.2 connector pads are 1mm in length so the cap pads should be .6mm, 0201 size.
1uf for C1570 coupling. 0603
https://www.digikey.com/en/products/detail/C0603C105K4RAC7411/399-C0603C105K4RAC7411CT-ND/12701838?itemSeq=371148843
100nf for C1571 coupling. 0402
https://www.digikey.com/en/products/detail/C0402C104K8RACTU/399-3520-1-ND/789660?itemSeq=371148883
M2x0.4 Pan Head Machine Screw Phillips Drive Nylon
https://www.digikey.com/en/products/detail/50M020040G004/145-50M020040G004-ND/11638015?itemSeq=371151403
THREADED STANDOFF
https://www.digikey.com/en/products/detail/SM3ZS067U410-NUT1-R1200/670-2865-1-ND/5955849?itemSeq=371262501
Alternative THREADED STANDOFF
https://www.digikey.com/en/products/detail/9774025243R/732-7079-1-ND/5320684?itemSeq=371266310
67 Position Female Connector M.2 (NGFF) Mini Card Gold 0.020" (0.50mm)
https://www.digikey.com/en/products/detail/1-2199230-6/A118046CT-ND/4729812?itemSeq=371311912
2.60mm Thermal pad to ?disperse heat" to MOBO end. Other m.2 drive has one under it's drive.
https://www.digikey.com/en/products/detail/57GF20500260500100/903-57GF20500260500100-ND/14325461?itemSeq=371260719
Last Edit: July 19, 2021, 07:35:26 pm by The Mad Atheist
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
