no no, the wah wah pedal is a pedal distinct from the Zoom G3 like the video in the first post
Ah ok.
the cables are not shielded but to reduce the ground loops I removed the ground from all the pedals except the first one. The pedals without gnd get it from the jack connectors
Which are two exactly wrong things to do. Audio cables carrying small signals (i.e. not speaker cables) always need to be shielded unless they are balanced, full stop. You could very well be picking up all sorts of crap there, even if the signal is at line level and not some weak microphone signal.
Relying only on the ground currents to flow through the jack connectors (and thus signal cables) will only bring more noise/hum into your system due to the ground potential differences between the devices (ground "moving" in 50Hz rhythm is the same as having 50Hz hum at the input of the device - only the difference matters and it doesn't matter which of the "wires" is "moving"). That's not how you break a ground loop! Now your ground loop is closed through your sensitive pre-amplifier circuit's ground instead.
The way to fix that is to do exactly the opposite - you connect the grounds of all your devices (pedals) together using a thicker piece of wire. That ensures that all devices are at the same potential and if there are any differences for whatever reason, they will equalize through this wire and not through the signal wiring (and thus affect the signal ground of the sensitive pre-amps). You will still have a loop but now no noise currents will flow through it where it matters (i.e. in the sensitive parts). If that doesn't help, you will need the transformers I have mentioned above and actually break the loop by isolating the offending device.
Studios also use something called a star grounding but that is likely not a practical setup on stage, where you have multiple power supplies and what not.
You can read a bit about how to properly deal with grounds here (and also how to track down noise issues):
http://analogrules.com/grounding.htmlThis is a bit more general but goes a bit more in depth in explaining how ground loops happen and why they cause noise problems:
http://web.mit.edu/jhawk/tmp/p/EST016_Ground_Loops_handout.pdfThat is not "separate ground" but separate power supplies
Sorry, you're right, not separate ground because the ground is in common the same through the jack connectors. This is the power supply I made it myself https://ibb.co/d984kG
Do the two voltage regulators have each its own transformer winding? Seems like they do, since I see two diode bridges there. If you care about blocking noise I would also consider adding a low pass LC filter at the outputs (choke + capacitor). That will help with any higher frequency noise and will reduce the mains hum. There are also some good tips here:
https://www.edn.com/Pdf/ViewPdf?contentItemId=4422750 E.g. that capacitor multiplier essentially completely eliminates mains hum from the output without having to use enormous capacitors.
