Author Topic: Hitachi v152f 15Mhz  (Read 1116 times)
Offline SkaylerTopic starter
  • Country: ie
Hitachi v152f 15Mhz
« on: August 28, 2022, 02:28:38 pm »
Hi guys. My name is Dean.I am new here. I live in Ireland and l am electrician. I have a quastion. I buy oscilloscope Hitachi V152f but l don't have a probes. I search on internet and l didn't find nothing. Can you help me where l can find it. Thank you.
Online Grandchuck
Re: Hitachi v152f 15Mhz
« Reply #1 on: August 28, 2022, 04:27:26 pm »
Hello and welcome Dean.  Have you looked at general purpose inexpensive probes as shown at Banggood and Aliexpress?
  • Country: ie
« Reply #2 on: August 28, 2022, 04:36:19 pm »
I didn't becouse l don't know what probes will work and what don't. I don't want buy something and when l connect it doesn't work. I am new in this so l don't know to muck about it. Can you send me a link from amazone or ebay what l can buy.
Offline rstofer
« Reply #3 on: August 28, 2022, 05:39:07 pm »
It is likely that there is a label on the panel below the BNC connectors that mentions something like 1Mohm 13 pF (from my Rigol DS1054Z) which is the standard input impedance.  Any 1 Mohm X1 probe will work.
Like these:
https://www.amazon.com/RioRand-PP150-Oscilloscope-Probes-Accessory/dp/B0030KWM30
Or you can buy far better probes at ProbeMaster.
  • Country: ie
« Reply #4 on: August 28, 2022, 05:46:40 pm »
Thank you for your help.1
Offline rstofer
« Reply #5 on: August 28, 2022, 07:03:16 pm »
FWIW, the probes I linked will have a switch to choose between 1x and 10x.  The probe compensation adjustment applies only to the x10 range.
Some scopes have a selector to choose between 1X and 10X since 10X clearly affects the display (1/10 as big) and any displayed values will be off by a factor of 10.
There is a long scope tutorial linked to the start of this forum.  The creator, w2aew, works (worked) for Tektronix and he really knows about scopes.  He has a lot of introductory level videos and all are excellent.  Google for w2aew, I suppose...
I like his op amp and transistor videos.  Dave has some good videos in that arena as well.
  • Country: ie
« Reply #6 on: August 29, 2022, 01:17:49 pm »
I will take a look on that videos. I like to learn about this.Thanks.
