I was looking at Daves power supply design. I have looked at both rev A and rev B and there is something I can not figure out why it was done. If you look at rev B on the ADC, the op amps have different voltage sources. One has the voltage source, while the other also has a cap and a ground. It i the same with the op amps in the PUS area of the schematic as well. Why is this?
