In my opinion, that is not a good way to do it. Don't the pins have 'interrupt on change'? Every time A or B changes, you get an interrupt. It is up to the code to make sure which edge is interrupting (and changing it on every interrupt) {maybe you are looking for a falling edge because the signal is known to be high then you are looking for a rising edge signal because the signal is known to be low}
I wrote this type of code for an ATmega128 quite a few years back.
#include <avr/io.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include <ctype.h>
#include "defines.h"
volatile int8_t RightWheelState = 0;
volatile int32_t RightWheelCount = 0;
volatile int8_t LeftWheelState = 0;
volatile int32_t LeftWheelCount = 0;
volatile uint8_t urx;
volatile uint8_t urx_recv;
/* Quadrature Encoder Scheme
* There are two pairs of quadrature signals, one for each wheel.
* The right wheel is on EXINT4 (PE4) and EXINT5 (PE5)
* The left wheel is on EXINT6 (PE6) and EXINT7 (PE7)
* Each encoder has two outputs A & B. For convenience, A is considered the MSB
* while B is considered the LSB.
const int32_t EncoderB[] = {+1,-1,-1,+1};
const int32_t EncoderA[] = {-1,+1,+1,-1};
SIGNAL(SIG_INTERRUPT4) // encoder B for right wheel
EICRB ^= 0x01; // toggle the edge bit
RightWheelState ^= 0x01;
RightWheelCount += EncoderB[RightWheelState];
SIGNAL(SIG_INTERRUPT5) // encoder A for right wheel
EICRB ^= 0x04;
RightWheelState ^= 0x02;
RightWheelCount += EncoderA[RightWheelState];
SIGNAL(SIG_INTERRUPT6) // encoder B for left wheel
EICRB ^= 0x10;
LeftWheelState ^= 0x01;
LeftWheelCount += EncoderB[LeftWheelState];
SIGNAL(SIG_INTERRUPT7) // encoder A for left wheel
EICRB ^= 0x40;
LeftWheelState ^= 0x02;
LeftWheelCount += EncoderA[LeftWheelState];
void IOInit(void)
UBRR0H = 0;
UBRR0L = BAUD;
UCSR0B = _BV(RXEN) | _BV(TXEN) | _BV(RXCIE);
static int uart_putchar(char c, FILE * stream)
if (c == '\n')
uart_putchar('\r', stream);
while (! (UCSR0A & _BV(UDRE)))
UDR0 = c;
return c;
SIGNAL(SIG_UART0_RECV)
uint8_t s;
s = UCSR0A;
urx = UDR0;
if (bit_is_clear(s, FE))
urx_recv = 1;
void QuadInit(void)
LeftWheelState = (PORTE & 0xC0) >> 6;
RightWheelState = (PORTE & 0x30) >> 4;
EICRB = 0xff; // enable rising edge triggering on INT4..7
EICRB ^= (LeftWheelState & 0x02) << 5; // if a signal is already set
EICRB ^= (LeftWheelState & 0x01) << 4; // set the interrupt to falling edge
EICRB ^= (RightWheelState & 0x02) << 1;
EICRB ^= (RightWheelState & 0x01);
EIMSK = 0xf0; // enable these 4 interrupts
int main(void)
IOInit();
QuadInit();
sei();
fdevopen(uart_putchar, NULL);
printf("Hello World\n");
while (1) {
printf("LWS =%2d LWC =%6ld RWS =%2d RWC =%6ld\n",
LeftWheelState, LeftWheelCount, RightWheelState, RightWheelCount);
The defines.h file:
#ifndef DEFINES_H
#define DEFINES_H
#define F_CPU (1474560UL)
#define CYCLES_PER_US ((F_CPU + 500000UL)/1000000UL)
#define BAUD (7) // 7 for 115200 baud with 14.745600 MHz clock
#endif
