Author Topic: It's got to be that easy! It has to be!  (Read 9258 times)
Offline shaneman20Topic starter
  • I like trains.
Re: It's got to be that easy! It has to be!
« Reply #25 on: April 12, 2015, 11:53:51 pm »
180 Amps!   :o
I hope that's a typo and you actually meant to say 18A.
If it is 180A then you want to make sure your alternator can actually produce that much current.  Not many can.
That's why I'm planning to look into it. It won't be for very long as far as the compressor being on. Relatively short.
I'll show you the specs on the manufacturer's website.
http://aircompressors.oasismfg.com/item/air-compressors/xd4000-continuous-duty-air-compressors/item-1052
The biggest thing is having an alternator that can keep up with charging the battery. That's the kicker. GM offers a 220A alternator, but I have to talk to the service guys first before I go about it and also have them piece together an auxiliary battery harness. Not sure what either will cost me, but it all just depends.
Shane Smiley
Railroading is my passion.
