Author Topic: Hope RF Module - HM-TRP 915 Hz, set to factory default  (Read 1035 times)
Offline bshambaughTopic starter
« on: February 09, 2019, 02:04:58 am »
I recently purchased a HM-TRP wireless transciever from Ebay. I am told that almost all modules purchased off Ebay have 3DR firmware, not the default factory firmware.
https://www.ebay.com/itm/HM-TRP-Wireless-Transceiver-915Mhz-HopeRF-w-simple-UART-Program-Interface-/181750129594 .
How easy it is to revert back to the factory firmware? Where can I find the firmware?
Offline tsman
Re: Hope RF Module - HM-TRP 915 Hz, set to factory default
« Reply #1 on: February 09, 2019, 02:50:14 am »
AFAIK the closed source Hope RF firmware isn't available. If you want to reflash the Si1000 on the HM-TRP then you need to buy/borrow a SiLabs debug adapter. There is an open source firmware replacement on github somewhere.
