So I am building a class D amplifier that operates in the RF range.
The input to the mosfet drivers of the amp take two square waves (5V TTL) where one is 180 degrees out of phase.
Currently I am using a signal generator, but I'd like to build my own driver.
To keep things easy (I am a beginner and not a real engineer), I just want to use a crystal oscillator. Using that oscillator, what is the simplest way to create the second wave that I need. I imagine I need logic inverter, but I've never made a circuit like this. What should I use? Keep in mind, I'd like it to be functional up to 20 MHz and low part count.
For a non-fixed frequency reference, I could probably use the cheap AD9850, but I really want something cleaner than that at the higher frequencies. Is there something similar to it (like better model) that I might be able to get on ebay as a module.
Thanks in advance!
