Author Topic: (solved) best way to simulate 30amps on components.  (Read 1501 times)
Offline whitevampTopic starter
« on: September 21, 2016, 07:17:15 am »
i am want to see how components react to 30 amps of current and i have used ltspice, multisim, and Circuit Wizard for this but i had noticed that if i place a dmm/ get the voltage at any node it will show 30kv useing an amp source of 30, but if i use 17vdc there is no amps/ very little.
so what is the correct way to simulate this?  :-//
PS: im looking at making a variable 17VDC 30AMP ( minus of coarse all the voltage drops from the components. ) CC/CV bench power supply from an old rv inverter  transformer that is 17VDC 30AMP.
« Last Edit: October 07, 2016, 06:32:18 pm by whitevamp »
Offline alanb
Re: best way to simulate 30amps on components.
« Reply #1 on: September 21, 2016, 08:31:53 am »
The load resistance on the output of your simulation will need to be 17/30 Ohm  i.e. 0.57 Ohm to draw 30 Amp from a 17 Volt supply.
Offline Delta
« Reply #2 on: September 21, 2016, 12:21:03 pm »
Ohm's law.
« Reply #3 on: September 21, 2016, 02:59:17 pm »
I see what my mistake was now.
I was just using an amps source, and not a voltage source and then using ohs law to figure out the correct resistor value.  |O  :palm:
thanks for the help with this issue/question.
