Author Topic: How a memory works  (Read 4599 times)
Offline little_carlos
How a memory works
« on: October 21, 2014, 12:47:08 pm »
Hey guys
ive been wondering, how a memory work? i mean, physically, what makes inside of it that saves data or something?
Offline Kdog44
Re: How a memory works
« Reply #1 on: October 21, 2014, 12:53:30 pm »
what type of memory are you talking about? RAM, ROM EEPROM .. etc
Offline atferrari
  • Country: ar
« Reply #2 on: October 21, 2014, 01:02:45 pm »
Hey guys
Generic questions like yours are better served if you go straight to a complete article or tutorial amongst the so many you could find in the Web.
Why not Google and then coming to the forum for details?
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
Offline Falcon69
« Reply #3 on: October 21, 2014, 01:08:05 pm »
i'd say it has to do with millions of latched type circuits holding 1 or 0 inputs.
like latching logic chips, flipflops, etc.  am i close?
Offline hamster_nz
« Reply #4 on: October 21, 2014, 01:16:13 pm »
Hey guys
The link a helpful person would give you is http://www.akkadia.org/drepper/cpumemory.pdf - "What Every Programmer Should Know About Memory". 114 pages, very dense in information. Read until you head explodes, the read it again
Section 2.1 has most if the information you are after.
Offline hamster_nz
« Reply #5 on: October 21, 2014, 01:26:13 pm »
Yes, for SRAM. But there are heaps of other technologies.
For most DRAM it is little leaky capacitors, holding charge while they are regularly topped up by refresh cycles.
For Flash it is a static charge/electrons that have tunnelled themselves into a little pocket above a FET junction, holding the gate open or closed.
For ROM it can be constructed that way, with metal connections on the silicon chip that encode what data will be read back.
For PROMS it might just be fuses that are blown when it is programmed.
There there is phase change memory and a whole lot of other exotic stuff like core memory
Online tggzzz
« Reply #6 on: October 21, 2014, 07:56:33 pm »
Don't forget mercury delay lines, core memory, bubble memory, or even moonbounce :)
Offline macboy
« Reply #7 on: October 22, 2014, 02:08:16 am »
Core memory is hardly "exotic", as it was one of the first ever electronic memory technologies.
Hey guys
I mean no offense, but haven't you ever heard of Wikipedia? It has excellent articles on all common (and uncommon) memory types, including principles of operation in relatively layman terms. http://en.wikipedia.org/wiki/Computer_memory
Offline Simon123
  • Country: si
    • Youtube channel
Offline Neilm
« Reply #9 on: October 22, 2014, 05:05:32 am »
Fram - magnetic memory that retains the information.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #10 on: October 23, 2014, 09:11:49 am »
Simplecpu.com will get you a basic answer.  Hope I am remembering that URL properly.
Direct link to that page: http://simplecpu.com/memory.html
« Last Edit: October 23, 2014, 09:13:38 am by Rigby »
Offline Richard Crowley
  • KE7GKP
« Reply #11 on: October 23, 2014, 10:20:20 am »
In the mid 1970s we made our own graphics terminals (because you couldn't buy one from anyone).
We had to use a magnetostrictive delay line to get the speed and capacity to buffer enough info to refresh the screen.
It looked like several turns of rather fine steel wire in a box about 12 inches square with an input and output transducer.
Not completely unlike spring reverbs still found in vintage (and retro) guitar amps, etc.
Offline coppice
« Reply #12 on: October 23, 2014, 06:16:02 pm »
Did you really mean the mid 70s? You seem to be describing mid 60s issues. By the mid 70s a number of graphics terminals were available, both complete terminals and modules for integration into consoles. I used quite a few of them. They didn't use delay lines either. DRAM was the normal buffer store by that time, for those which needed a buffer store. Storage tube graphics terminals, of course, did not require any form of buffer store.
Online tggzzz
« Reply #13 on: October 23, 2014, 07:31:40 pm »
Interesting. That vaguely rings a bell, but it might be one of my remaining neurons misfiring.
What was the delay and bandwidth (or number of bits)? (I presume it wasn't analogue, since each trip around the loop would have added noise.)
I'm mildly surprised there was little (no?) attempt to keep the successive loops separated, so as to minimise crosstalk and ghosts. But that reveals my ignorance.
I should also, of course, have mentioned Williams CRT memories.
  • KE7GKP
« Reply #14 on: October 24, 2014, 01:27:55 am »
Yes, I believe you are correct. It was more like mid-late 60s now that you jog my memory.
I have a vague recollection that it was several K bits.
I believe the data was regenerated for each trip (not unlike refreshing DRAM).
I thought the mechanical action was axially through the length of the wire, but I never investigated it.  I wondered about the loose winding also. Note that there are some examples of the technology where the loops are held apart by "bearings" and brackets...
Offline gxti
« Reply #15 on: October 24, 2014, 01:46:28 am »
And now it's quite dead, so I guess that makes it exotic again.
Storage tubes are another fun one. Draw on a CRT, then read it back: https://en.wikipedia.org/wiki/Storage_tube
Offline hamster_nz
« Reply #16 on: October 24, 2014, 07:00:59 am »
I wonder how much core memory has ever been produced? I'm would bet that I have more memory in my cell phone (272 Gbits, flash+RAM)...
Mike
