What is it about soldering that compels amateurs (and unskilled veterans) to produce soldering training materials showing subpar soldering quality? It happens over and over and over, despite the ready availability of good training materials by skilled professionals.
Hi, I have been repairing and restoring my Atari 2600, and I wanted to show off my soldering skills.
They're... fine? Certainly not bad, but not at educator level.
I hope beginners can use this to see how a solder joint is supposed to look. Notice the shiny, uniform blob that covers the entirety of the pads.
Well, then even the improved pictures (in the updated original post) are not a good example. Many joints have too much solder, and there are lots of really bad joints that I assume are ones you didn't get to yet. And "blob" isn't what a good joint should look like. The proper term is a "fillet", whose proper appearance I describe below.
Also, the quality of the photography is low, further reducing the educational value.
Also notice how it looks volcano-like, and not apple-like. Notice that there is not an excess amount of solder on the joints.
If it's volcano-like (i.e. the fillet is neither concave or convex) then it's already too much solder. The correct amount of solder leaves a
concave fillet.
The main things to note are that the solder joints are not rough-looking or dull. They are shiny, smooth, and round. They do not have holes or cracks. That is a proper joint.
While true of leaded solder (which is all one should use when repairing devices originally manufactured with leaded solder), with lead-free solder, a satin finish is fully acceptable. Even and uniform, but not mirror shine. (A matte surface is unacceptable, though.)
Remember to watch for smearing though, it can and will catch you off guard if you aren’t attentive enough!
Smearing and protrusions are indicative of what I call "overcooked" solder. This is due to excessive dwell time and/or rework of the joint. It's caused by oxidation (which can be prevented by use of additional flux) and alloy contamination (as the PCB traces and components dissolve copper or gold into the molten solder, changing its composition). The latter is only preventable by working fast. Once the solder is contaminated in that way, the only solution is to suck it off and replace it (working quickly) with fresh solder. Also, when correcting a smeared or protruded joint, after sucking off the overcooked solder, the soldering iron tip must be freshly tinned, since the solder on it can be oxidized and/or contaminated, so you basically want to "rinse" the tip with a few changes of fresh solder before
(Indeed, military/aerospace soldering standards specify for gold-plated components and boards that the lead or pad must first be wetted with solder, then the solder sucked off, before soldering the joint, to remove the gold plating so it doesn't contaminate the joint.)
I hope this doesn't come off as too harsh, but you have learning to do. I cannot recommend enough the PACE video series tggzzz linked above. There is no finer tutorial on through-hole soldering, and much of what they explain also carries over to surface mount.
Ooh, soldering thread!
What do you all think of my crappy efforts? (I think I have a habit of using just a tiny bit too much solder, maybe I should use thinner solder..)
I don't often get the chance to have someone look at my stuff.
Not bad at all. Better than the OP's, both in the joints and photography.
