Do manufacturers of electronic components select their own part numbers (MPNs), or are these selected by an independent body? Is there any guarantee that part numbers are unique? If so, are there any permitted exceptions to uniqueness? For example, if I search 2N2484 on mouser I see a number of devices from different manufacturers with the same part number. In this case, I could see that it might be deemed permissible for different manufacturers to use the same part number if the datasheets specs are identical.
Actually, in the example I gave, it seems 2N2484 is covered by MIL-PRF-19500/376. So, maybe any components that meet those specs can be identified as 2N2484.
