Hello people, I need to make a circuit to limit current of a fixed voltage polarity reversal power source using two LM334 current limiter IC.
Let's say I need a 28V constant voltage at the output and need the current to be limited at 8mA, can I use two LM334 IC with a 1N5819 Schottky diodes connected at their inputs/outputs to direct current depending on the polarity of the power source? See images below that shows current direction depending of polarity direction...
Also, the polarity reversal is not fast, maybe once every 5 minutes...
Will this work?
