Author Topic: How are wires connected to this power strip?  (Read 1986 times)
Offline fubar.gr
  • Country: gr
    • Fubar.gr
« on: November 06, 2015, 10:20:08 pm »
Someone posted these pics of the internals of a power strip on another forum.
How are the wires connected to the busbars? Is it some kind of glue?
Online Towger
  • Country: ie
Re: How are wires connected to this power strip?
« Reply #1 on: November 06, 2015, 10:29:50 pm »
I was going to say spot welded, but it looks like glue!
Offline Sbampato12
  • Country: br
    • Sbampato.com
« Reply #2 on: November 06, 2015, 10:36:34 pm »
On first picture there is a spot weld indication inside. The main question is, this weld is with the cable, or between the two metal stripes? :-//
If I need to choose, I would say that is just glue on cables....
Offline mij59
« Reply #3 on: November 06, 2015, 11:09:40 pm »
Very poor connection, some of the copper stains are spot welded, the rest are held in place  with glue, only the spot welded strains will carry current  :-- :--
Offline Cliff Matthews
    • General Repair and Support
« Reply #4 on: November 07, 2015, 12:48:21 am »
China strikes again, this time burning down our houses as part of a silent war. Some estimates already say 1 million Africans now die per year due to fake Chinese malarial drugs. All this because the West is agreeable and stupid enough to put faith in hand-shakes and trade deals without punitive measures to back them up. Please don't import their food - it will be the end of us. What I really want to know, is how far they will go till we notice the major events on the radar..
Offline Macbeth
« Reply #5 on: November 07, 2015, 02:18:00 am »
Nah, it's been soldered ok. They just spray paint it afterwards so the scrap metal it's made from won't rust and looks like copper.
Offline Ampere
« Reply #6 on: November 07, 2015, 03:29:00 am »
I'm going to go out on a limb and say that it's not UL listed.
Offline Monkeh
« Reply #7 on: November 07, 2015, 03:47:35 am »
I'm going to go out on a limb and say UL have nothing to do with it as it's not from the US.
Offline Sbampato12
  • Country: br
    • Sbampato.com
« Reply #8 on: November 07, 2015, 04:13:35 am »
Here some started import they food. Some fish (here called "pangá" or something like that). We already got alerted that this fish is normally living in a junk water, even with high concentration of heavy metals... but hey, it is cheap :--
Nowadays is very hard to find good power strips, at least on my location....
« Reply #9 on: November 07, 2015, 05:12:59 am »
Euro socket, and yes it looks like they spot welded them ( poorly) then put the hot snot to hold the pieces together so the little flakes of CCA that will invariably fall off the plated steel ( brass is expensive, so just brass plate it, she'll be all right) will still not fall out of the plastic housing.The 2 halves of the conductor strip are not spot welded together, that looks more like a formed rivet in the metal, a mechanical fastener.
Amazing is that the cable conductors actually are the right number of strands, and the PE is the same number of strands, I regularly see that the PE is half the metal and twice the plastic ( guess which is cheaper) in cables.
Yes the modern made stuff, even from reputable manufacturers who have an established name for quality products, is now a lot poorer, with the material being thinner, the rating being nominally the same but in real life they do not meet this. If I try drawing 16A ( the rated current in S Africa) from a modern outlet plate, using a cheap 16A rated plug, it will overheat and possibly catch fire. Outlet uses thin brass which loses spring after 5 insertion cycles, and the plug that goes in it uses a plated hollow steel pin with stamped wire terminals, not the old one which uses a brass stamping with a backing spring steel collet to ensure contact, and the plug has solid brass pins with a cut thread for the wire holding screw.
