Author Topic: Waterproofing Outdoor Enclosures - Cable Gland Alternatives  (Read 3424 times)
Offline Thane of CawdorTopic starter
« on: January 29, 2018, 03:53:49 pm »
Hi all,
A quick question: are there any alternatives to using cable glands (like these: https://uk.rs-online.com/web/p/cable-glands/0389599/) for waterproofing the input/output cabling to an outdoor project box/enclosure? Is there a search term for something similar that has a smaller size since the thread on these variants are generally too big to fit onto the side of a small profile hobby box (with a height of ~ 40mm with the lid).
Alternatively, has anyone ever just fitted a silicone sleeve over the wires, drilled a hole between the hobby box lid and main chassis and then screwed together - essentially clamping the silicone sleeve to make the hole watertight (protecting the electronics inside)?
The cable I'm running through is a simple power cable (~5mm in diameter)
Offline David Hess
  • DavidH
Re: Waterproofing Outdoor Enclosures - Cable Gland Alternatives
« Reply #2 on: January 29, 2018, 08:46:56 pm »
If design considerations allow it, then running the cables through on the bottom should be good enough.  Even with good cable glands, I would use drip loops on the inside.
The following users thanked this post: Thane of Cawdor
Offline james_s
« Reply #3 on: January 29, 2018, 09:53:42 pm »
Sometimes sealing the box completely does more harm than good. I've seen water seep in up higher and slowly fill up a box that tried to be completely sealed. Had it been able to drain out the bottom it would have likely been ok.
Offline Paul Moir
« Reply #4 on: January 29, 2018, 10:13:18 pm »
You should be able to get those quite small, certainly small enough to fit a 40mm height box.  For example a very common one with a PG9 thread should fit no problem.  The nut's OD is 24mm.
(I would still drill a tiny hole in the bottom at the very least.  I had one application where the moisture transfer though the wire insulation transferred into the sealed unit causing condensation within.  The solution was to drill a tiny hole.  :)  )
« Reply #5 on: February 01, 2018, 03:46:09 pm »
Hmm they probably don't in this case but that's interesting - do you mind explaining how you'd use the drip loop inside the project box?
« Reply #6 on: February 01, 2018, 03:50:23 pm »
Ah I see! Although, wouldn't the hole allow for condensation to occur within the box (and hence the electronics could be negatively affected) even if the box doesn't fill with water?
Offline David Hess
  • DavidH
« Reply #7 on: February 01, 2018, 05:32:58 pm »
Immediately after the cable or wires enter the enclosure through the side or top, they are formed into a loop so that any water which leaks in and follows the cable or wires will drip off at the bottom instead of continuing to where the cable or wires terminate.
A drip loops are more often used outside of an enclosure but they work inside as well for defense in depth.
Offline picandmix
« Reply #8 on: February 01, 2018, 06:12:25 pm »
Given the 40mm height of your box , wonder what its other dimensions are , fairly small ?
Also how much space is taken up with the electronics and are any of them likely to generate any heat at all ?
What kind of outdoor min / max  temps are we talking about as you do not show a country flag.
You will never avoid some condensation etc, so where possible use a protective lacquer coating on your board instead .
Unless your cable is going to be tugged or moved around a lot, a simple rubber cable gland is all thats needed, or just a hole and the cable bedded with some silicone rubber sealant.
Offline floobydust
« Reply #9 on: February 01, 2018, 09:59:06 pm »
Use cable glands. The plastic ones are low cost, and ensure water/splash/rain storm/melting snow will not get in your enclosure.
Or put your enclosure inside another enclosure which is like a rain hood. You see this in weather stations as a Stevenson Screen.
Offline james_s
« Reply #10 on: February 02, 2018, 01:18:27 am »
If the design allows for this, another option is to pot the whole box in epoxy. I normally don't like potted stuff because it makes repair very difficult but it's an option in some cases.
