Author Topic: Schematic understanding... how do I interpret this?  (Read 570 times)
Offline JupitusTopic starter
« on: January 23, 2024, 04:34:10 pm »
Hey all! May be a daft question, but can someone please explain to me how to interpret this on a schematic ?
Offline TimNJ
Re: Schematic understanding... how do I interpret this?
« Reply #1 on: January 23, 2024, 04:44:04 pm »
I'd guess it indicates a PCB "solder bridgeable" jumper.
Something like the bottom four "parts" in the attached photo. Drag solder between the two pads to solder them together.
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
« Reply #2 on: January 23, 2024, 07:39:37 pm »
My best guess other than what TimNJ said is an SMD fuse, as it looks like that components might have a current rating. 175mA fuse?
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
Offline pcprogrammer
« Reply #3 on: January 23, 2024, 07:52:17 pm »
The text above the symbol says it is a jumper with dimensions 43*39. The current being mentioned looks like a hint for others that it typically is 175mA.
I find the solder-able jumper explanation far more likely then it being a fuse symbol.
Edit: even the part reference PJP10 more likely points to a jumper than a fuse.
« Last Edit: January 23, 2024, 07:55:00 pm by pcprogrammer »
Offline BrokenYugo
« Reply #4 on: January 23, 2024, 08:14:17 pm »
I've seen something like this in a Chinese transistor radio kit, each stage of the circuit had a solder bridge on the Vcc trace and the expected current given. I think the idea was you were supposed to build it stage by stage and test to sort of confirm you built it right.
