Given the general build quality, the amount of circuitry (including protection, preamp and so forth) and the adherence to ratings, I don't doubt that this is a quality Sony product. (As opposed to a cheap Sony product, for which it's important to remember: neither term is exclusive. Sony is a huge company and makes both consumer and professional equipment!)
But, as with ALL automotive power amplifiers I have seen, they commit the cardinal sin: neglecting filter inductors, leaving off current mode protection, assuming that the 12V input won't do anything sudden and dangerous.
The only safe way to build a switching supply is with some means of monitoring and controlling the switch current, and switching that current into an explicit inductance.
The uPC494s are wired for maximum duty cycle, except during startup, when they rise, v-e-e-e-r-r-y-y, s-l-o-w-l-y, to mitigate inrush.
If the secondary side goes shorted, it explodes.
If the primary side surges, it explodes.
If the primary side voltage varies, the secondary side has no regulation (not that regulation is really necessary for a linear amplifier).
Will it ever die? Not necessarily. But that doesn't excuse bad design decisions. It's particularly disappointing, having seen some rather novel power supply designs from other Sony departments, e.g.
http://seventransistorlabs.com/Monitor/index.html the resonant SMPS with saturable reactor control.
If this is a "build from scratch" kind of thing, you'll have no end of trouble trying to debug the power supply itself, and inevitably having it fail many times (filling up half a bucket with burnt transistors). And then building the amplifier side, and having it fail many times, taking out the SMPS in the process (and filling up another bucket and a half with transistors lacking magic smoke).
Not that kilowatt power levels are all that easy to work with in the first place. You really need a good understanding of circuits to build one of those.
(This is an example of how a '494 might be used, in a more safe manner:
http://seventransistorlabs.com/tmoranwms/Circuits_2010/12-24_Converter.png It has a current sense resistor on the switches, which feeds back to the controller. The transformer is wound for extra output voltage, so it can be PWM'd down to the required level, and filtered with an inductor. The feedback and compensation loops are all wrong, but again, this is just an example. There are plenty of much better controllers out there, with fast current control, stable operation, and fail-safe by nature. Or you can build your own out of comparators and stuff -- which is a rather laborious process, but there's perhaps no better instruction than seeing the contents of one of these chips in action on the macro scale.)
