WimberleyTech didn't explicitly state it, but input and output impedances (often called Z11 and Z22) are always measured open circuit. Output impedance with the input open, input impedance with the output open. Even with things like antennas the same model is used, although there is no "output" per se, the input is measured as if there is an open output. Admittances (Y11, Y22) are measured with the opposite end
shorted.
This means C has an input impedance. Then B+C has an input impedance, but to measure B alone you'd need to disconnect C from it. Same with A+B+C. On the output side, A has an output impedance measured with the input open as drawn and B disconnected. The A+B, with C disconnected, and finally A+B+C has a joint output impedance.
Hope this helps understand in/out impedances.
