You cant. All the datasheet gives you is typ. and max. Reverse Recovery Times (Trr) for the reverse current to drop to 25% of its initial peak. You have to decide what proportion of the reverse half-cycle you can tolerate it conducting for without excessive losses, and, allowing for any asymmetry in the waveform, decide what *YOU* regard as its frequency limit in *YOUR* application.
