Hi, all;
First time posting, and I'm looking for assistance from some circuit experts. Recent EE graduate, here. Embarrassed that I can't get some simple circuits working! Any help is appreciated...
Goals:
- Make a noninverting comparator circuit. Vcc = ~12V, Vthreshold = ~10V..... these values are to be experimented with, once I get the circuit functioning.
- not terribly committed to my hysteresis value yet, but <500mV would be nice
- Comparator will eventually be used to trigger a 555 Timer (LM397 OUT will be attached to 555 TRIG, and *hopefully* Timer will be triggered on falling edge signal from LM397)
Successes so far:
- Inverting circuit (attached below) is functioning. I just eyeballed the resistors to get things going. Inverting circuit has values of VH = 11.1V, VL = 11.0V, with VCC = 12V.
- ummm other successes..... I haven't melted the LM397 yet?
Failures so far:
- I don't care about the inverting circuit working... I want a noninverting comparator
- noninverting comparator circuit refuses to light up, both by "playing around with values" and by mimicking TI's example circuit (PDF attached below)
- significant attack on pride and confidence
Requests:
- Please suggest how my noninverting circuit needs tweaking. As soon as I get it working at all, I should be okay to tweak.
- if LM397 isn't the right fit, then please say so
- Be nice, I'm trying.
Notes:
- yes my LED is facing the right way
- yes I've checked my math (using TI's PDF, it was basically plug-and-play calculations), but please feel free to ask specific questions
- have not used a scope on the circuit yet
Thank you for reading. Hopefully I've provided enough details!
