Author Topic: how can I disable auto-standby on TV soundbar?  (Read 35568 times)
Online Ian.M
Re: how can I disable auto-standby on TV soundbar?
« Reply #25 on: December 01, 2024, 09:15:41 pm »
You are obviously an expert dead-bug/freeform prototyper, and I have no doubt that for *YOU* it was faster to prototype just with a soldering iron rather than switching to coding half way through.  However many here are less good with an iron and would benefit from considering the MCU approach.
Online peter-h
« Reply #26 on: December 02, 2024, 07:44:42 am »
It's call a "birdsnest" over here :)
If you use a micro then you have to birdsnest that too, or use some sort of evaluation board, or design a PCB. And you still need to solder. It's going to take way longer.
This is only a 100 quid soundbar...
Offline Zero999
  • 0999
« Reply #27 on: December 02, 2024, 09:38:51 am »
This circuit will inject 20kHz for 100ms every 5 mins into one of the two audio channels going to the soundbar
I am not yet sure of the required level i.e. the value of the 100k resistor on the output.
The two chips are CMOS 555s.
Why use two 555s? A single 556 will do.
And why PWM the power to the second 555 when you can just PWM the reset pin?
This circuit works at 40kHz, at a repetition rate of 100Hz, but you get the idea.
* 555 burst.asc
Online peter-h
« Reply #28 on: December 02, 2024, 09:59:10 am »
The idea is to not have any power on the 2nd 555, 99.999% of the time.
Can't do that with a dual 555.
Offline Zero999
  • 0999
« Reply #29 on: December 02, 2024, 05:50:53 pm »
If it's about low power consumption, then two oscillators made with the '4011 or 4001 quad NAND or NOR gate IC will use less power than two CMOS 555s.
Online peter-h
« Reply #30 on: December 02, 2024, 07:52:50 pm »
That's true. And one could get into the nanoamp area with a circuit built with some discrete MOSFETs...
But even better to put this inside the soundbar.
