Author Topic: High side power FET switch ideas needed. (maybe charge pump/gate driver?)  (Read 781 times)
Offline OddTopic starter
  • Country: no
The mission is to switch 3-40v  , up to 10A.
The signal is a MCU output, between 0 and 3v3.
I could always do something like the traditional high-side PFET design (black attachment)
it would perform poorly if the voltage to be switched is low.
2387679-0
What I would really like is the hand-drawn thing, where the questionmark is some charge pump with very few external components, and I can control the gate of the NFET from logic level.
2387683-1
Offline PGPG
Re: High side power FET switch ideas needed. (maybe charge pump/gate driver?)
« Reply #1 on: September 30, 2024, 07:15:42 pm »
About your traditional PFET design.
What is PFET type that accepts 42V gate-source?
Using NMOS at high side you need voltage higher than high switched voltage.
You said no word for how long the switch have to switch the load on. If it is like in DCDC converter only several us than there is no special problem with supplying with capacitor, but if it have to be switched on for hours you have to made some permanent source to drive NMOS gate.
You also said no word why load can't be switched on the low side making the NMOS solution much simpler.
Offline langwadt
« Reply #2 on: September 30, 2024, 07:16:13 pm »
how fast, what duty cycle?
  • Country: no
« Reply #3 on: September 30, 2024, 09:32:07 pm »
very slow, basically on/off in a per minute basis, so no need to make the transition very fast.
As for PFET and the GSvoltage, well, this is why I seek advice  :)
I do not wish to switch it on the low side because the different outputs will supply different subsystems, which have common ground and ground wired in data-connections.
« Last Edit: September 30, 2024, 09:34:21 pm by Odd »
Offline Benta
« Reply #4 on: September 30, 2024, 09:37:59 pm »
In that case, the simple solution is a photovoltaic optocoupler.
Like this one:
https://www.vishay.com/en/product/83469/
« Last Edit: September 30, 2024, 09:47:58 pm by Benta »
Offline BrianHG
« Reply #5 on: September 30, 2024, 09:38:11 pm »
Just use an N-Channel Mosfet with a photo-voltaic.
~20ma into the LED, and the photovoltaic will output ~18v for the Gate regardless of any other system voltages.
This one has fast turn-off circuitry built in, so no external jfets needed:
https://www.mouser.ca/ProductDetail/Toshiba/TLP3910C20-TPE?qs=TuK3vfAjtkUvVtweYOqjVw%3D%3D&srsltid=AfmBOorsWvMG9Vb9B8uyFlksa3zT4Ro7OeIp8r8kHHBu1gWuYg8y3fQ0
« Last Edit: September 30, 2024, 10:32:37 pm by BrianHG »
Offline BrianHG
« Reply #6 on: September 30, 2024, 10:32:47 pm »
Like this one:
Warning, that photovoltaic only delivers 8.9v.  The one I recommended delivers at least 14v, normally 18v.
Offline Benta
« Reply #7 on: September 30, 2024, 10:38:10 pm »
"Warning"? Thanks a lot.
But yeah, the TLP3910 is nice. I thought Vishay was state-of-the-art here, but am mistaken.
Downside to the TLP3910 is that you'll need a voltage booster circuit for driving the LED. But that's pretty simple.
Offline BrianHG
« Reply #8 on: September 30, 2024, 10:54:04 pm »
Sorry, I didn't mean to offend.  Just in case you miss the 9v and do not use a logic level mosfet, you may potentially have a partially turned on mosfet baking circuit if you are driving a huge amount of current.
I do not think that it is if Vishay is state-of-the-art or not, they must have a real reason for their 9v we just do not know about.  The toshiba part probably just has 2x in series compared to the vishay part.
It could be something as annoying as a patent rights issue.
If you have a 5v rail somewhere, then all you need is an open-collector output to drive the LED.
I would personally recommend a transistor driver as ~15ma on an MCU IO is doable, but I know something like a 2n3904 or 2n2222 will always hit the LED at my prescribed current through a series resistor.
« Last Edit: September 30, 2024, 11:10:34 pm by BrianHG »
Offline artag
I have a similar problem.
A PMOS transistor switches on a battery (3.7 - 4.2V) supply to a 61088 boost converter generating 5V. The PMOS transistor fails to achieve it's best on-resistance, probably due to the low battery voltage. At lowest battery voltage I have highest current drain and worst sensitivity to on-resistance. Like the OP, a common ground makes it difficult to switch the negative rail.
I'm considering whether to attempt to provide a supply for an NMOS fet, bootstrapped by using a capacitor to initially turn it on and then maintained by the boost converter's output.
Does this sound feasible, or overcomplicated ?
Offline Benta
« Reply #10 on: October 01, 2024, 09:26:53 pm »
Don't hijack a thread, start your own.
Thanks.
Offline Smokey
  • Not An Expert
« Reply #11 on: October 01, 2024, 09:50:46 pm »
https://www.digikey.com/en/products/filter/power-management-pmic/power-distribution-switches-load-drivers/726
Parametric search from there.
Something like this maybe..
https://www.digikey.com/en/products/detail/texas-instruments/TPS27S100ARRKR/10715408
You can also use an "ideal diode" controller with a FET of your choice to meet requirements.  Work the enable on the controller and it acts like a high side switch.
LM74502DDFR Maybe...
https://www.digikey.com/en/products/detail/texas-instruments/LM74502DDFR/15904171
Offline artag
« Reply #12 on: October 01, 2024, 10:40:26 pm »
Thanks.
The common thing here is to keep subjects together when they're tightly related as this is. This sometimes leads to long threads which is a disadvantage, but it saves digging out a bunch of separate ones that the search tool may not find.
I'm surprised you don't know this given your long posting history, but hey, not worth arguing about.
Offline Benta
« Reply #13 on: October 01, 2024, 11:01:12 pm »
I see no tight relationship.
Make a new thread instead of injecting noise.
Offline PGPG
« Reply #14 on: October 02, 2024, 09:04:00 am »
The thread problem is: P-switch that is good for 40V is not good for 3V and P-switch that is good for 3V is not good for 40V.
Where did you get the idea that your 3.7V ... 4.2V problem is tightly related to this?
Offline Seekonk
« Reply #15 on: October 02, 2024, 01:59:38 pm »
I have a 60A DC SSR that appears to use the VOM1271 from package and voltage. It reaches 7.5V max and the FET driven is likely a IRFP4332.  To fully turn on it takes over 7ms with that gate capacitance.  So, anyone using these should be prepared for real slow turn on. It does have quite a fast turn off.  And if device is battery operated with potentially low voltage or an analog drive which can be low, the fast turn off circuit does not work.  It will allow gate voltage to get under 2V and force the FET into a linear region.  Just a friendly warning.
