SN7413 Positive quad input dual NAND gate in circuit attached. Pins 3, 5, 10, 11, 12 and 13 are floating, see image of PCB tracks. How can it work if one input is always zero (floating) please? Basically the board controls two big SCR's which adjust the mains input voltage level to a linear power supply's transformer's primary to reduce voltage drop across the pass transistors. It appears to work, but how....? Thanks.
Thanks.
