Author Topic: checking voltage  (Read 1554 times)
Offline slaghammerTopic starter
checking voltage
« on: June 06, 2015, 06:26:38 pm »
 You say. If in doubt check voltage. I understand that all meters are different so if a part in a circuit is supposed to be 4v at what
plus and minus point would you call it bad.
Thanks. Leo
Offline SL4P
  • There's more value if you figure it out yourself!
Re: checking voltage
« Reply #1 on: June 06, 2015, 10:16:15 pm »
+/- 5% max, then start to ask why... unless the supply is marked as being better than 5%
Don't ask a question if you aren't willing to listen to the answer.
Offline picandmix
« Reply #2 on: June 07, 2015, 09:00:48 am »
If you are concerned about the accuracy of your meter, then get one of the cheap 5v volt reference diodes like a LM4040 or one of the many similar devices to see how good it really is.
Some meters do have internal adjusters to you can recalibrate for that particular range.
