Author Topic: AR488 with HP1630D  (Read 398 times)
Offline VivisTopic starter
AR488 with HP1630D
« on: May 30, 2021, 02:16:31 am »
Hi all,
I have an HP1630D I'm trying to get an inverse assembler on. I've built the AR488 and can get the HP to respond to button press commands and rst, but i can't quite get an assembler to load. Honestly, I'm not even sure I'm sending it right. I've been trying to send the files via coolterm's send text/binary file function. The best I can get out of the 1630 is a CRC error. I have been able to successfully invoke the TC command but have not been able to reload the config that TC generates.
Thanks for any suggestions in advance
The following users thanked this post: WaveyDipole
