850 approaches visible light, I bet you that you may be able to see a slight glow under magnification or especially with a camera that normally sees infrared light more than others (my old cell camera was brilliant at it)
850 may be stopped by black, and 940 may pass through - some materials such as black developing film may block 850 all together. Output/relative wavelength surely are different on some IR diodes as well if you can find a large enough difference and standardise a test.
Alexander.
OK, old ones are VERY bright at 3V, without anything I can see a red dot inside, with the cellphone I see a lot of violet light
840 ones at 3V are like 30% less brighter than the last ones, but I can see a very small red dot inside
940 ones at 3V are like 30% less brighter than the 840, but I can't see a small red dot inside.
Maybe my old ones are less than 840 nm?
