I'm not used to the Australian versions of Ford's stuff, but I'm more than familiar with the American counterparts, and general automotive theory.
Ballast resistors limit coil current, nothing more or less. If you ran constant battery voltage directly to an old oil-filled coil, it would overheat and likely fail, go pop, and maybe BOOM! and smoke.
They do a lot more than that!
When a car starter is operated,the battery voltage drops from the nominal 12 volts ,down to around 8 or so volts.
With a normal 12 volt ignition coil,directly connected to the battery via the ignition switch,the result is a reduced voltage spark at the plugs,just when the best spark is required for starting.
Automotive Electrical system designers devised the ballast system to get around this problem.
A coil designed to produce full spark with a lower primary voltage (commonly called an "8 volt coil") is used with a series resistor,during normal running.
When the starter is operated,the series resistor is bypassed,the coil still produces normal spark,& the car starts more easily.
As soon as the starter switch is released,the circuit reverts to normal.
It works,too!
I had a Mitsubishi Colt Galant back in the late 1970s,which was a brute to start in cold weather.
When I looked in the Workshop Manual & compared it with my car,I discovered that Chrysler Australia, who were assembling them, had seen fit to remove the ballast & run a "12 volt " coil.
I couldn't find a Mitsubishi ballast,so I fitted a Datsun one,along with an "8 volt" coil from an after market parts place,
"Hey Presto!", Cold start problem fixed.
If you run a coil designed for ballast service direct from your 12 volt battery---Yes,they will get hot!
Coils designed to run directly from 12 volts don't get hot,but they
still have worse cold starting characteristics.
