Author Topic: Help me find this plug  (Read 471 times)
Offline dasloloTopic starter
  • I saw wifi signal once
« on: April 04, 2020, 10:26:39 am »
This old telescope from 2000 has a GPS patch with a plug that looks like a u-fl, maybe a tad larger diameter (difference below 0.1mm) but the center hole that receives the pin is wider, maybe by 0.1 or 0.2 mm so the patch antenna doesn't fit a u-fl receptacle of the new gps module I want to attach.
Is that plug MHF3? Is there an adapter to u-fl I can purchase?
« Last Edit: April 04, 2020, 10:39:45 am by daslolo »
nine nine nein
