This is ridiculous. You can purchase audio amps on eBay for $12. With 24V 3A power supply, you'll get plenty of boost.
And that would be a ridiculous idea. The original poster requires a signal, not a power amplifier.
If it's a ready built solution the OP is looking for, then he should search for a pre-amplifier, not a power amplifier.
See the circuit attached. I use two resistors to create a virtual ground, as I use a single 9v battery, as suggested by BilliyO
you will either have to use a split supply or create a virtual ground at Vcc/2.
As I mentioned, it seems to work when I connect it to the output of my laptop, but not to the receiver....
PS:
Apologies for the quality, I will try to get some software do depict schematics
It sounds like an issue with loading. The rail splitter has an equivalent resistance equal to both of the resistors connected in parallel, which is 1k. This isn't a problem, at DC, because they only carry the tiny bias currents, but at audio frequencies, the voltage will bounce around, when the circuit drives a small load. Adding bypass capacitors will reduce the impedance of the ground node considerably, by charging and discharging as the op-amp's output swings between positive and negative.
A couple of other notes:
I would recommend adding another resistor to limit the gain to a maximum level, otherwise it'll make the potentiometer difficult to adjust and it very easy for the op-amp to be driven into saturation.
I've added labels to denote the voltages in the circuit, with the all important 0V node, the point from where all voltages are referenced to.
EDIT:
Is this a stereo amplifier?
Why use the old LM741? It's pretty noisy and doesn't work well off such low voltages.
It would be better to use the TL074. One op-amp for each channel, with the other as a rail splitter. The spare op-amp could be used to boost the rail splitter circuit and reduce the impedance, without big capacitors.
