Author Topic: How do I boost the audio output?  (Read 2113 times)
Offline EpovoTopic starter
« on: January 20, 2024, 06:43:23 pm »
I recently bought a wireless microphone. The receiver has a jack and I plugged into the AUX input of my soundbar. The problem I have is, that even with the receiver knob to the max and the soundbar to the max as well, the sound is not too loud.
So I thought I needed some amplification; not much, maybe 5X. I went ahead and made a simple one-transistor amplifier following the attached circuit. The amp works fine when driving an 8 ohm speaker. But if I insert it into the line from my receiver to the AUX input, I can't hear anything. Not that I am susprised - the circuit was never designed for that purpose. But I don't know what else to try. Any help would be appreciated-
Offline BeBuLamar
Re: How do I boost the audio output?
« Reply #1 on: January 20, 2024, 07:19:17 pm »
An OP amp would work.
The following users thanked this post: Epovo
Online BillyO
« Reply #2 on: January 20, 2024, 09:25:12 pm »
That "amplifier" is just about as wrong as you can get.  The input impedance will be extremely low and the distortion would be crazy.  Look up a simple class AB design and use a properly configured class A pre-amplifier.
« Last Edit: January 20, 2024, 09:32:04 pm by BillyO »
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline schmitt trigger
  • Country: mx
« Reply #3 on: January 20, 2024, 09:35:34 pm »
Additionally, the poor speaker would have its cone permanently halfway or more out, due to the DC current flowing thru it.
Offline MarkT
« Reply #4 on: January 20, 2024, 10:32:13 pm »
My take on a single stage line-level transistor amp:
on reflection C1 can be larger like 2µ2 for better bass.
« Last Edit: January 20, 2024, 10:34:05 pm by MarkT »
« Reply #5 on: January 21, 2024, 01:07:28 pm »
I think I will try the OP amp solution. Thank you all
Online BillyO
« Reply #6 on: January 21, 2024, 03:10:12 pm »
It won't work.  If you drive that transistor of yours with an op-amp you will only end up basically shorting it out.  Most op-amps will deliver only a few mA (maybe 39 or so) and it will not do anything to improve the situation as mentioned above.
There is a reason amplifiers are designed the way they are and it's because that's what you need to do to get them to work. :scared:
Online langwadt
« Reply #7 on: January 21, 2024, 03:23:04 pm »
did you even read the OP? an opamp would be perfectly fine for ~5x gain for a line input
« Reply #8 on: January 21, 2024, 03:25:46 pm »
No, you misunderstood. I'm gonna get rid of that amplifier, that I should have never built. I am going to insert the OP amp between the output of the receiver and the  AUX input of my soundbar.
Online BillyO
« Reply #9 on: January 21, 2024, 03:27:27 pm »
You see this working do you?   Did you look at his circuit?
Online BillyO
« Reply #10 on: January 21, 2024, 03:28:29 pm »
Okay, that sounds better. Yes, I did misunderstand.
« Reply #11 on: January 23, 2024, 05:56:24 pm »
I used an op amp t741 in the configuration on the image below, but the output does not look good (input is a sine wave) (see attached image). Other than an op amp malfunction, I don't know what else could that be...?
Online BillyO
« Reply #12 on: January 23, 2024, 05:58:13 pm »
Are you running it off a single supply?
Your input signal is pure AC so you will either have to use a split supply or create a virtual ground at Vcc/2.
« Last Edit: January 23, 2024, 06:00:12 pm by BillyO »
« Reply #13 on: January 23, 2024, 05:59:35 pm »
Yes I am... :-\
Online BillyO
« Reply #14 on: January 23, 2024, 06:00:38 pm »
« Reply #15 on: January 23, 2024, 06:03:48 pm »
thank you so much. I'll do that the virtual GND thing
Online Zero999
  • 0999
« Reply #16 on: January 23, 2024, 07:10:49 pm »
In addition to the other criticisms of the original schematic, C1 is backwards and will be biased with 0.6V of the wrong polarity. If it doesn't damage the capacitor, it will introduce more distortion.
I would suggest using an amplifier IC such as the LM386, if this hasn't been recommended already. I admit, I'm in a rush so haven't had time to read the entire thread.
https://www.ti.com/lit/ds/symlink/lm386.pdf
Online langwadt
« Reply #17 on: January 23, 2024, 08:31:26 pm »
no point in a poweramp and to do ~5x gain of a mic/line signal
Online Zero999
  • 0999
« Reply #18 on: January 23, 2024, 11:41:19 pm »
Alright I've had a bit more time to read the thread properly now.
There are different types of amplifiers. The type used to drive a speaker, is a power amplifier, whilst the type you need to boost the signal a bit for a sound bar is a small single amplifier.
The op-amp solution will work, but it needs to be biased to half the supply voltage and the signal coupled by capacitors.
Below are a collection of op-amp circuits showing the dual and single supply configurations. The original poster needs the top right one.
Oh I forgot to ask: is it run of a battery, which isn't powering anything else, i.e. a really smooth power supply? If so, the circuit can be simplified a bit, but I'll have to post it later, as I don't have time now.
The following users thanked this post: YurkshireLad
« Reply #19 on: January 25, 2024, 04:54:31 pm »
Thank you all for your help. I am using the simplest one, which I attach. For R1 and R2 I am using a 10K potentiometer.
Using a signal generator (the audio ouput of my laptop) I can see the circuit amplifying in the amount I desire by adjusting the potentiomenter. So apparently it works fine. BUT when I connect the circuit into its final destination (between the output of my receiver and the AUX input of my soundbar) I hear nothing.
Using the oscilloscope I can see that there is a signal coming out from the receiver when I talk into the mic, *as long as the output of the receiver is not connected*. As soon as I connect it to my circuit, I can't see the signal anymore, even if the power of my amp is off. What could be happening here?
PS:
If I connect the receiver to the AUX input of my soundbar (thereby bypassing my amp), it still works, but as I said in my opening post, the sound is too low.
Online Zero999
  • 0999
« Reply #20 on: January 25, 2024, 04:59:37 pm »
How is the op-amp powered? Please post a schematic showing exactly how it's connected to the power supply.
Note, the circuit you've posted needs a negative, as well as a positive power supply rail. It will not work properly from a single power supply.
« Reply #21 on: January 25, 2024, 05:28:24 pm »
See the circuit attached. I use two resistors to create a virtual ground, as I use a single 9v battery,  as suggested by BilliyO
As I mentioned, it seems to work when I connect it to the output of my laptop, but not to the receiver....
PS:
Apologies for the quality, I will try to get some software do depict schematics
Offline alligatorblues
« Reply #22 on: January 25, 2024, 06:29:21 pm »
This is ridiculous. You can purchase audio amps on eBay for $12. With 24V 3A power supply, you'll get plenty of boost.
« Reply #23 on: January 25, 2024, 06:36:40 pm »
Thank you @alligatorblues. I know I can buy it. I am doing this in part to learn something.
Online langwadt
« Reply #24 on: January 25, 2024, 06:39:48 pm »
Online Zero999
  • 0999
« Reply #25 on: January 25, 2024, 06:53:52 pm »
And that would be a ridiculous idea. The original poster requires a signal, not a power amplifier.
If it's a ready built solution the OP is looking for, then he should search for a pre-amplifier, not a power amplifier.
PS:
It sounds like an issue with loading. The rail splitter has an equivalent resistance equal to both of the resistors connected in parallel, which is 1k. This isn't a problem, at DC, because they only carry the tiny bias currents, but at audio frequencies, the voltage will bounce around, when the circuit drives a small load. Adding bypass capacitors will reduce the impedance of the ground node considerably, by charging and discharging as the op-amp's output swings between positive and negative.
A couple of other notes:
I would recommend adding another resistor to limit the gain to a maximum level, otherwise it'll make the potentiometer difficult to adjust and it very easy for the op-amp to be driven into saturation.
I've added labels to denote the voltages in the circuit, with the all important 0V node, the point from where all voltages are referenced to.
EDIT:
Is this a stereo amplifier?
Why use the old LM741? It's pretty noisy and doesn't work well off such low voltages.
It would be better to use the TL074. One op-amp for each channel, with the other as a rail splitter. The spare op-amp could be used to boost the rail splitter circuit and reduce the impedance, without big capacitors.
« Last Edit: January 25, 2024, 06:57:19 pm by Zero999 »
« Reply #26 on: January 25, 2024, 07:02:55 pm »
Thank you all very much. I found out what was going wrong - It was a rookie mistake (the kind I do) with the connectors  ::)
Offline tooki
« Reply #27 on: January 26, 2024, 10:34:01 am »
Namely…?
Offline EPAIII
« Reply #28 on: January 26, 2024, 11:02:51 am »
If you want to learn about OP Amp circuits and how to design them, try
The OP Amp Cookbook, by Walter G. Jung.
It is somewhat old, but the basics do not change, just the IC part numbers. And even the classic 741 still works today. I have made line amplifiers like you want with them many times. It can have a high impedance input and can supply enough current at the output to drive almost any audio input, which should be high impedance.
And if your 741 circuit lacks performance in some area, there are many, many OP Amps with the same pin-outs and better specifications that can be plugged into the same socket as the 741 to provide better performance. I have started with a 741 many times and pulled it and just substituted a better one. That works quite well for audio circuit design.
But you gotta have a dual (+ and -) supply or make a virtual ground in your circuit. And if you use a single supply, it (the supply) can't share a ground with either your input device or your output device.
https://nortonsafe.search.ask.com/web?q=op%20amp%20cookbook&ssdcat=321&lang=en&source=nag&year=2015&locale=en_us&geo=us&version=22.23.10.10&plang=sym:en&buildname=retail&heartbeatid=4ae3d98c-56e4-4df2-adf1-00b1d085e47e&eapenabled=false&env=prod&vendorid=1014930&plid=866&plgid=41&skup=21389648&skum=21376863&skuf=90001202-fa&endpointid=4ae3d98c-56e4-4df2-adf1-00b1d085e47e&lic_type=2&lic_attr=17059858&psn=7jjxx287wjvq&templatecat=sbu_w_1000_5039_n360dsp_retail&schemacat=sbu_w&schemaver=1.0.0.0&olpchannel=retail&osvers=10.0&oslocale=iso:usa&oslang=iso:eng&os=windows&showuninstallsurvey=1&installstatus=updated&vendorsrc=firefox&machinelocation=us&sw=0&3in1=0&npw=0&hp=0&dsp=0&cdest=nag&annot=false&vendorConfigured=ask&o=APN12178&prt=ngc&ver=3.21.0.6&tpr=111&chn=1014930&guid=4ae3d98c-56e4-4df2-adf1-00b1d085e47e&doi=2023-11-26&browser=FireFox&prod=DS&doi=2023-11-26&installSource=nag&cmpgn=oct23&darkMode=false&sameTabLaunch=false
« Last Edit: January 26, 2024, 11:08:07 am by EPAIII »
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
« Reply #29 on: February 11, 2024, 02:07:32 am »
EDIT:
My point is the futility of reinventing the wheel again and again. If all the OP wants is a SIGNAL, what is he going to do with that? Given the choice of designing and building a one-off  integrated amplifier, or purchasing one for $12 is pretty much a no-brainer. I can only assume people are ignorant to such solutions. Rather than perpetuate it, I make rational suggestions.
I once purchased a board amp, installed it in an enclosure, put connectors on for Power, Signal, Speakers, Volume; connected it to a PC, and it kicked ass. The entire sound system cost about $50, and took about 3 hours to make. Do certain people have an aversion to saving time, effort and money. I sold that system 3 years later for $187+ some cents.
Blanket advice to everyone seeking an electronics project: stop reinventing the wheel! Don't use Arduino. Don't purchase kits. Don't pay outrageous prices because it isn't available anywhere else. Because it is. You just have to look. I needed a 1.0 Ohm resistance standard +(-) 10ppm. I purchased a L&N off eBay. I spot welded a ~3/4" ( 19mm) length of Manganin that I annealed  until its tempco was about 1.000008 per meter.
I spot welded that wire in parallel with the existing resistive element, and it's been hanging off my 34420A for weeks. It is +-10ppm, period. So, I took a $70 resistor, gave it a littler tlc, and now I have a $2500 resistor.
If you're going to invest the time, effort, skill and money; for the love of all that is good in this world, gain something tangible for your effort. That reminds me of one of the best kept secrets in the world! No matter how interested chicks pretend to be in a man's work skills and accomplishments, their sole interest is how it translates to income. Which reminds me of another one of the best kept secrets in the world.
Since most guys can't just pick the hottest chick in view, take her home, and have sex; guys never get a chance to learn; No matter how hot the babe, you'll get sick of her just as fast.
Online Zero999
  • 0999
« Reply #30 on: February 11, 2024, 09:56:45 am »
What a bizarre rant.
Exactly how does that help the original poster, with boosting the signal level of a wireless microphone, to the level required for the auxiliary input of a soundbar?
The following users thanked this post: langwadt, tooki
