Say you wanted to check to see if the gutters or metal work on your house was grounded or all connected. Other then taking a meter and a super long piece of wire if there a device that can measure this through RF or other means? Say you wanted to use the gutters on your house as a lightning rod or even ground rod how would you do that if laying huge amounts of second conductor isn't doable like where the metal passes through the house. Is there a net working tool that does this?
