Last few days I have been trying to power up a 400V capacitor with no luck. I need to make a circuit similar to a flash circuit from a disposable camera. I tried with few different transformers from old pc power supplies, but with no luck. I understand how transformers work. You need AC or pulses of DC trough the smaller coil to induce bigger voltage on the bigger coil.
http://www.repairfaq.org/sam/strbfaq.htm I found circuit design here, it's under "Super Simple Inverter". My real problem is finding a transformer that will suit my needs. I would also like to know if its possible to just use a step-down transformer with its pins other way round? I get the idea of center tapping in transformers, but what is the main difference between center tapped and non center tapped? I noticed in the schematic that always one of the center tapped coils is charged, so does this mean that center tapped transformers are more efficient? I use 5V 450mA power adapter, and arduino to make pulsating dc current. I studied lot of camera flash circuits, but I still don't get some of the more in depth thing about transformers. Till now I only managed to measure AC voltage of few mV on the secondary coil, it makes a LED turn off and on. I know the noob force is strong within me
. I would appreciate any help.
